Looking into having T5 speedo drive gears made
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
As most of you know the speedometer drive gear for T5's have been discontinued. The only source for them I know of is used transmissions in the bone yard, and they are keen on me tearing a trans apart to get the gear out of it. I use these gears in my T56 speedometer drive conversions.
I've contacted a few companies and they are willing to make them for me in small quantities. But thy won't be cheap. My cost will be right at $60 each with an up front investment of over $2000.
My question is, how many of you are in need of these gears? I'm going to have the 7 tooth made, 99% of us need the 7 tooth and not the 9 tooth.
I'd like to make a little on this, not looking to make a huge profit, was thinking of making about $10 each over my cost for my time and investment.
I welcome your thoughts.
Car: `86 SS / `87 SS
Re: Looking into having T5 speedo drive gears made
does that mean I can send you eight new GM 7 tooth gears and you'll speedo-cable modify a couple T56 tailhousings?
Car: 87 IROC-Z28
PM me and we will talk about it.
Car: 1989 Camaro IROC-Z Convt.
Engine: 355
Axle/Gears: Zexel Torsen 3.42
Ever get anywhere with this? I've been making my own gears for the T5's and it is a big PITA
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Any thoughts to having the driven gears made as well? Especially for the VSS equipped cars?
On Probation
Engine: several
Transmission: none
Axle/Gears: none
First, these same gears can be found in Chevy ( NOT B-O-P ) TH350s. Second, why use these at all? Much harder to get a precision calibration with so few teeth. Use the 15-19 tooth drive gears for 700R-4, then create a way to use the larger carriers for the 34-45 tooth driven gears. This gives much more options, and the parts are cheaper and easier to find.
Engine: 355
Wrong. They are not the same gear, the ID of the TH350 gear is larger than the T5. I use the TH350 7 tooth and a T5 9 tooth to make my gears.
Edit: Also, using the 700r4 stuff would require machining a new tail housing...not in the least bit practical
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The driven gears and the gear housing from TH350's will fit the T-10 and T-5, according to PATC:
http://www.transmissioncenter.net/sp...____va.htm#350
JamesC
JamesC
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Bull. Both the TH350 and the T5 use the exact same 27-spline slip-yoke for the front end of the driveshaft. Total interchange. If the T5 shaft gets bigger, then hone the gear out. Even so, stop using the obsolete no-calibration garbage.
Engine: 355
JamesC
JamesC
Having built three T5's and converted two to cable driven, I can assure you that parts are not compatible. Not trying to start a pissing match, but I did all the research needed for this.
These are the gears I make:
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
you can still buy these gears through 5speeds.com for under $20.
Engine: 355
Ford, not GM. GM production has ceased years back, which is why threads like this have been around. Once again - I'm not trying to make people angry...the 7 tooth GM T5 gears are hard to come by
beachrodder
Aug 7, 2015 04:27 PM
