th200 too th350 ?s
Old Mar 14, 2012 | 08:02 PM
82z28 wrencher's Avatar
Car: 84 Trans Am
Axle/Gears: 10 bolt 3.73 factory
th200 too th350 ?s
was wondering if a swap from the 82 th200 to a th 350 would be a direct swap or if the driveshaft length would be a issue will it bolt into the crossmember and will the shifter lingages line up?
also will any th350 work like out of a truck perhaps ???
just looking for info thanks
Old Mar 14, 2012 | 09:37 PM
krisner89's Avatar
Car: 87 camaro
Transmission: th350
Axle/Gears: auburn 4.10
Re: th200 too th350 ?s
ya your driveshaft will work. most guys try to find a car like yours with a th200 in junk yards to take the shaft out for there swap. if its got a 700r4 trans then the shaft would be to short.
don't know about the crossmember but mine is modified so that it would work. little cutting and welding. b&m sells conversions kits also if you couldn't modify it(if it even needs modified).
its gotta have a 6 inch tailshaft(most common). a 4 inch or a 9 inch wont work with your drive shaft.
measure from where the tailshaft housing mates to the tranny case to the end of the out put shaft.
Old Mar 14, 2012 | 09:48 PM
Car: 84 Trans Am
aawww sweet just what i wanted too know im hoping it will just bolt into my crossmember thxs again and yeah its the turbo 200 in it says metric 200 on it lol and its a slush box its gotta go lol
Old Mar 15, 2012 | 07:59 AM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
If you can find a Monza TH350 tail for the tranny it will have the required torque arm mounting points.
Old Mar 15, 2012 | 05:24 PM
Car: 84 Trans Am
aawww shoot i didnt even think about that.... will my turbo 200 tail mount onto a turbo 350? perhaps? and if not what carried the monza tail so i can hunt for one
Old Mar 16, 2012 | 09:18 AM
nosajwols's Avatar
Car: 82 Z28
V8 Monza's had short tail TH350s (at least some did, that is where I got mine). No idea on the TH200 tail on a short tail TH350.
I imagine the Monza TH350 tails are hard to come by (I got mine 20 or so years ago).
Old Mar 16, 2012 | 10:08 AM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
have you concidered just swapping in a camaro 700r4 and matching driveshaft?especally since you have 373 gears...
Old Mar 16, 2012 | 10:19 AM
krisner89's Avatar
Car: 87 camaro
Transmission: th350
B&m sells a kit for the tailshaft bracket adaptor. u would need a torque converter lockup harness and controller if u wanted to get a 700r4 trans. unless its a drag only car i would mate a 3.73 gear to a th350. 700r4s have a low first gear so 3.73 gears might be to low.
Old Mar 17, 2012 | 11:58 AM
Car: 84 Trans Am
yeah i considered the 700r4 but i like the old school feel of the 3 speed no o/d its not going cross country so its good and thanks i was hoping someone made the bracket http://www.jegs.com/i/B%26amp%3BM/130/30299K1/10002/-1
ok so with this combined with a 6" shaft th350 i should be good to go Thanks everyone
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
romcjr
Sep 17, 2015 05:18 PM
LittleFranks
Sep 17, 2015 12:22 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
