How bad did I hurt my tranny?
Old Mar 19, 2012 | 10:37 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Today going to the hospital because my grandma had a stroke my car decide to start vapor locking, well it died on me in the middle of an intersection causing me to painic, when I put my car into neutral to try to restart it I got nothing so I ended up shoving my car into park before I thought about it while I was going. About 40, as soon as I heard the grinding I pulled it back into drive toll I could stop. Well now my car shifts higher than what it did and I get a small like rattle noise from my tranny when it's in drive or over drive. What did I do?
Old Mar 20, 2012 | 12:51 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: How bad did I hurt my tranny?
Sounds like the trans. was unhappy and cut itself.
Old Mar 20, 2012 | 05:50 AM
Engine: L31 350
Can I get a serious answer
Old Mar 20, 2012 | 07:38 AM
Engine: L31 350
Cars not shifting till around 3500 rpm and when it shifts it shifts hard.... I need help
Old Mar 20, 2012 | 10:07 AM
Engine: L31 350
TTt
Old Mar 20, 2012 | 11:59 AM
Engine: L31 350
All gears still work and it goes into park
Old Mar 20, 2012 | 02:34 PM
Engine: L31 350
TTT
Old Mar 20, 2012 | 03:03 PM
marc12321's Avatar
Car: 1987 Camaro
Engine: 355 4bbl
Transmission: tko 600
Axle/Gears: 12bolt 3.73
all park is is like a little pin that locks your gears. if you put it in park and roll you got a problem. if its good in park just listen for a while and be nice on it until your positive nothing broke
Old Mar 20, 2012 | 03:14 PM
Engine: L31 350
I tried park last night and it's still stable and doesn't roll, weird thing is I drove it around town for like 15-20 minutes today and after a while it started shifting like normal, smooth and low rpm shifting, I'm lost. Tv adjustment time again??
Old Mar 20, 2012 | 03:19 PM
marc12321's Avatar
Car: 1987 Camaro
Engine: 355 4bbl
i would try to adjust it again. just be carefull adjusting it couse you can easily burnout your trans. could the reason it stalled have to do with the high shifting?
Old Mar 20, 2012 | 04:17 PM
Engine: L31 350
No it started stalling out because my engine was vapor locking so it want getting fuel . I adjusted it and all seems good
Stroopwafel
Sep 11, 2015 06:38 AM
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
