It wont stop Leaking!!!
Old Apr 16, 2012 | 08:49 PM
IroczFan's Avatar
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
i have a baslicly brand new rebuilt 700r4 i put in my car and after maybe 200miles on it, it started to leak on the passanger side when all warmed up and it leaks when taking sharp left hand cornors. replaced the seal where the kick down goes, i called the guy who rebuilt it and thats what he suggested.. im all out ideas. ive put so much time and money into it and then this problem pop up does anyone else think they know what it could be its coming from the passanger side. im 99% sure its not a line scince it only leaks on cornors and when warmed up
Old Apr 16, 2012 | 09:04 PM
Re: It wont stop Leaking!!!
Sounds like the fill tube O-ring
Old Apr 17, 2012 | 06:57 AM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
i dont think it is tho because there is a rubber boot in there to. and i pretty sure after it gets done leaking its not wet that far up the trans
Old Apr 17, 2012 | 08:17 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i had a similar problem and it was the o-ring on the fill tube. it couldnt hurt to change it, theyre cheap.
Old Apr 17, 2012 | 05:07 PM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
alright i think it might be the filler tube O ring i warmed it up again and seen just a few drops coming from the way front of the trans and thats the only thing it would be but i will keep a eye on it to make sure
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
85 Jimmy
Sep 30, 2015 07:56 AM
84redta
Sep 19, 2015 09:58 AM
bubbaz28
Sep 18, 2015 02:09 PM
bamaboy0323
Sep 12, 2015 07:14 PM
