new spohn x memeber and torque arm mount....LOUD Noise when taking off
Old Apr 22, 2012 | 10:16 PM
1988TransAm22s's Avatar
Car: 1988 TRANS AM procharged
Engine: 305 procharged TPI with 5 speed
Transmission: 5 speed
Axle/Gears: 3:73
Just like the title says...i have upgraded to the spohn cross memeber and torque arm set up..after installation i took it for a ride and noticed a very loud noise when i got on the gas hard...sounded like somthing was loose but i went back under and checked everything and it was all tight...It almost sounds like something is hitting my floor but i dont know what it is...i contacted spohn and they said something was loose but i rechecked everything and it was all tight and greased...i know it is all mounted solid now but should there be that bad noise...please guys help me...im planning on installing my new procharger and im afraid of breaking something so im holding off till i figure it out...
Old Apr 23, 2012 | 12:03 AM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: new spohn x memeber and torque arm mount....LOUD Noise when taking off
Tranny mount has to be loose. I experienced the same thing before after doing some tranny work. If you ease on the gas you dont get the thump but when you hammer it sounds like someones taking a sledge hammer to your floor.
Old Apr 23, 2012 | 12:37 AM
87350IROC's Avatar
Car: 87' IROC
Two things to check.
First did you get the crossmember with integral driveshaft safety loop? My loop was really close to the floor pan. I modified it for more clearance. Also check for clearance between loop and driveshaft.
Second the bolts provided for the rotator have shoulders that are too short. You need to replace them with longer bolts with the proper size shoulder. I have seen this solve noise issues for several people. You may then have to cut the extra threads off the longer bolts.
Old Apr 23, 2012 | 07:08 AM
Axle/Gears: 3:73
Ok I checked the tranny mount and it's tight. The tranny doesn't move when I hear the noise. Also yes I did notice that the safety loop was very close to the floor but durin inspection there was no marks telling me that it hit the floor. I sent spohn another email and hopefully I get a better response. Thanx guys for the reply
Old Apr 23, 2012 | 07:55 AM
Look at the part of the torque arm where it bolts to the pumpkin; check it for hitting the floor on the side of the trans tunnel.
Very common in cars with the defective stock LCA geometry; aggravated by sagging wore-out springs and the need for LCARBs. It's part of the whole "wheel hop" syndrome these cars are born with and does nothing but get worse with age and wear, and with certain modifications.
Old Apr 23, 2012 | 03:56 PM
Axle/Gears: 3:73
ok i got a reply from spohn today and they say that its the rear pumpkin part hitting the floor but it sounds like it right under the tranny tail...i will post more updates after i get it up on the host and do a major inspection..thats for the help guys
Old Apr 25, 2012 | 02:05 AM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
i have A 92 CAMARO AND HAD similar symptoms. take a look on the inside of the tunnel back by the rear seat. there is a bracket that holds the fuel lines (at least in 92 models) the bolt was hitting the the top part of the torque arm on acceleration and decel. i removed one of the bolts and it took care of the problem. the top of the torque arm was a bit nicked, no biggie
Old May 1, 2012 | 10:19 AM
windowrattler's Avatar
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
Just an update for people with similar problems we found the pinion angles were off. The rear was pointing about 6+ degrees upwards. Straightened it out to about level and the sound is gone. Will have to set it all up with an angle finder but for now it is a lot closer.
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
