MK6 vs M39 1st gear ratios?
Old May 3, 2012 | 02:51 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
The MK6 T5 was bundled with the G92, N10, 3.45/3.42 gear cars and the M39 T5 with the non-G92, 3.08 geared cars. It's common knowledge that 5th gear on the MK6 T5 is steeper (.73 vs .63) than on the M39 T5. But I've seen conflicting info on the 1st gear ratio of the MK6.
I've seen it listed as both the common 2.95 ratio and also with a 2.75.
Does anyone know which it is?
Old May 3, 2012 | 03:04 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: MK6 vs M39 1st gear ratios?
2.95
Old May 3, 2012 | 03:22 PM
chazman's Avatar
Axle/Gears: BW 3.45
Originally Posted by jmd
2.95
Are we 100% on that?
Old May 3, 2012 | 07:32 PM
jmd's Avatar
jmd
I'd be happy to create you one if you want to pay for it but it won't involve a stock countershaft.
Old May 3, 2012 | 07:42 PM
chazman's Avatar
Axle/Gears: BW 3.45
Oh, I don't want one. I just wanted to verify that they both came with a 2.95 1st gear and that the 2.75 stuff is all bogus.
Old May 3, 2012 | 07:44 PM
jmd's Avatar
jmd
Where are you seeing it listed with the 2.7x first gear? Besides 5speeds.com applet list.
Old May 3, 2012 | 07:55 PM
chazman's Avatar
Axle/Gears: BW 3.45
I've seen in afew places, namely some magazines of the day. And it keeps popping up now and then.......
Old May 4, 2012 | 12:21 AM
jmd's Avatar
jmd
Well, it looks like 5speeds fixed their list; it had 2.74 first gear in the description line for some of the codes years ago.
I was honestly hoping it was still showing 2.74 first there (or somewhere like http://www.britishv8.org/Articles/Bo...T5-ID-Tags.htm ) so you could have an opportunity to call a Tremec parts dealer and verify the countershaft service # as the same for a 1352-196 for example.
Post up any "popping up" events as you see fit.
Old May 4, 2012 | 08:27 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Noone has ever posted any tooth counts, anywhere, for the mythical 2.75:1 first that I also have seen in many places. And with only a 3.45:1 axle, why would there be? Need at least a 10:1 combined first to get the best from a manual with a 305.
Old May 4, 2012 | 10:07 AM
chazman's Avatar
Axle/Gears: BW 3.45
Thanks jmd, I think we can finally put this 2.75/2.74 1st gear stuff in the BS column.
Old May 4, 2012 | 01:36 PM
jmd's Avatar
jmd
I say we have Kevin follow up on his decade old posts. https://www.thirdgen.org/forums/post...094-post4.html
Joe needs to correct his site: http://members.cisdi.com/~anesthes/gear.html
https://www.thirdgen.org/calculations used to be
https://www.thirdgen.org/newdesign/t...ulations.shtml
So yeah, a few updates could be made.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
dbrochard
Sep 19, 2015 08:13 PM
scottmoyer
Sep 7, 2015 07:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
