9 bolt gear oil
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
9 bolt gear oil
I did a search and I see the BW 9 bolt does not get the posi additive. I also found the GM part number for the gear oil 1050010. I haven't found that part number being sold, but did see a post stating that that GM has since changed the part number to 89021671? Anyone have any info on the correct part number for the BW 9 bolt...Thanks
Re: 9 bolt gear oil
Just go to the store and get some gear oil. You don't need to get it from GM. Not something to outsmart yourself over.
Personally I prefer Mobil 1.
Car: 89 Formula 350
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: 9 bolt gear oil
I use mobil one in the rear, the motor (including filter), and the trans. I even use it in my lawn mower.
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: 9 bolt gear oil
The GM Firebird service manual states to use the additive. This is stated in both the section on 10 bolt and the section on the 9 bolt.
Car: 89 Formula 350
Re: 9 bolt gear oil
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: 9 bolt gear oil
I have been running Mobil One 75W-90 in mine for quite awhile. No problems.
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: 9 bolt gear oil
regular gear oil is fine. it uses cones (metal on metal to give you anti slip). there is no clutch material so no need to use friction modifiers. if you think you need to use the additive you can it wont hurt it but its not "needed"
synthetic is ok too.
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
Navy8125
Aug 21, 2015 09:32 AM
