Convertor Recommendation
Old Jun 24, 2012 | 09:51 PM
iroc90dfi's Avatar
Car: 1990 IROC-Z
Engine: 355 TPIS Mini Ram, Vortech R-Trim
Axle/Gears: 3.73 Strange S60
Need a recommendation for a lock-up convertor 3K stall for my supercharged car. Keeping my 700r4 and plan to drive the car more often. I would like to know what brand you guys are running.
Old Jun 26, 2012 | 03:07 PM
Pro Built Automatics's Avatar
Re: Convertor Recommendation
I would go with the Vigilante 9.5" or 10.5". They offer a 5 year warranty and a free 2 year stall change if desired. If you have any questions here, let me know. Dana
Old Jun 26, 2012 | 05:31 PM
iroc90dfi's Avatar
Car: 1990 IROC-Z
Are you using one now?
Old Jun 27, 2012 | 08:53 AM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
Im using a holeshot 3600 on th350 and im loving it its not a lock up converter thou
Old Jun 30, 2012 | 10:09 AM
iroc90dfi's Avatar
Car: 1990 IROC-Z
Where did you get it from?
Old Nov 25, 2012 | 12:12 AM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
From Summitracing
Old Nov 28, 2012 | 12:53 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
X2 on a Vigilante. I'm running a 9.5" single clutch lockup on my 700r4. Bought it from Dana. It is advertised as a 3200 stall, flashes right at 3k on launch. It's a little looser than I'd like once I get up on boost but that's the trade off. I haven't heard too many good things about B & M convertors. I'm pretty sure they are just a modified stock convertor. I ran a Holeshot 2400 before the Vig and I it was night and day better with the Vigilante. A lot lighter too being that it's not 12".
Old Dec 5, 2012 | 09:50 AM
iroc90dfi's Avatar
Car: 1990 IROC-Z
Thanks for the response, looks like Vigilante is the way to go. I was about to buy a Hughes convertor before your post.
Old Dec 5, 2012 | 11:12 AM
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
I've heard good things about TCI, I went with a 10" Streetfighter 3000 for the TH350 that's going in. Haven't used it yet though.
Old Dec 5, 2012 | 11:25 AM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Vigilante or Yank if you have the cash.
My latest is a TCI Super Streetfighter (LS1) unit. Supposed to be about 3200 with LS1. It works ok gor my setup so far. With a sticky track and tires, im hoping I can footbrake it higher. It spins my streettires just past 2400rpm now and 0 boost. Instant boost/tirespin when I go WOT though. it was $150 used so I gave it a shot.
Old Dec 5, 2012 | 03:31 PM
When foot braking, do not go over 1,800 rpm with most 3,500rpm or less stall on the launch. The higher the launch rpm wise, the less torque multiplication. That is why foot braking can give you better 60 foot ET's than a transbrake.
Old Dec 5, 2012 | 04:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
All my cars have 60'd better when footbraking as high rpm as possible before brakes pushed thru.
This was using 3 different edge converters in 2 different cars all under 3600 stall.
I run a ptc in my th400 for boost. Have run several edge racing converters with good success and cheaper than vig or yank. Several good brands out there
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Nervous2
Oct 8, 2015 10:53 PM
1nastygta
Sep 24, 2015 08:58 AM
overdriv
Aug 20, 2015 03:52 PM
