TH-350 Driveshaft Question
Old Jul 7, 2012 | 10:31 AM
Blue_IROC_86's Avatar
Car: '82 Camaro Z28 (Former Pace car)
Engine: 85 5.7L Small Block
Transmission: WC T5
Axle/Gears: 96 disc LT1 3.23 Auburn 10 bolt.
I am switching from TH-350 to a 700-R4 for economy reasons. The parts i have are as follows
700-R4 from an 86 IROC
Kick down cable for a 4bbl
700-R4 Flywheel
and the tranny mount for the R4
Now my question is, Is the drive shaft from the 350 going to have the same spline as the 700-r4? If it does fit. what other kinds of issues could i encounter?
This is my daily driver so i dont want this to get hung up.
Old Jul 7, 2012 | 12:22 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TH-350 Driveshaft Question
The front yoke is the same between the 700R4 and TH350. The driveshaft will need to be either replaced or shortened.
RBob.
Old Jul 7, 2012 | 12:30 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
If your TH350 has the short tail shaft the drive shaft will need to be shortened but if it has the 9inch tail shaft it will work with no modification.
Mark.
Old Jul 8, 2012 | 08:18 AM
Transmission: WC T5
sweet lol. well i hope its a 9 inch tailshaft
Old Jul 8, 2012 | 08:26 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I thought the short tail shaft for the th350 was 6" long.
Old Jul 8, 2012 | 08:28 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If it is the OEM TH350 that came in the '82 cars, it will be the short tail version.
I think that you may also require the shorter torque arm.
RBob.
Old Jul 8, 2012 | 08:36 AM
Transmission: WC T5
RBob.
I just measured it. its a 6inch
Now why do i have to have shorter Hardware if its not a long tailshaft?
Old Jul 8, 2012 | 09:10 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
the 700R4 is longer than the TH350 with the 6" tail housing which means it uses a shorter driveshaft. the torque arm is also shorter for the 700R4 unless a change over kit was used to install the TH350 in place of the 700 to begin with.
Old Jul 8, 2012 | 09:18 AM
Transmission: WC T5
Yes sir you are right. I figured that out when i got under my car..
well thanks for the help!
Irocguy01
Sep 28, 2015 02:03 PM
theshackle
Aug 23, 2015 03:49 PM
overdriv
Aug 20, 2015 03:52 PM
redmaroz
Aug 16, 2015 11:40 PM
