changing shifter shaft seal in 700r turbo transmission
Old Aug 20, 2012 | 07:55 PM
roger85camaroz's Avatar
I've been looking in my chilton book and can't find directions on how to change this seal would appreciate any help I can get. Thanks
Old Aug 20, 2012 | 10:55 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: changing shifter shaft seal in 700r turbo transmission
pick it out.
tap the new one in with a driver.
Old Aug 22, 2012 | 10:39 AM
Now how do I get the arm off the shaft or do I have to take the transmission out and do this work from the inside?
Old Aug 22, 2012 | 10:17 PM
jmd's Avatar
jmd
Look at it with a mean eye. It'll jump right off.
Or you'll see the removal involves a nut.
Old Aug 22, 2012 | 11:15 PM
I did see that but how do u get the shaft to not move because it kept trying to spin and it felt as thow it was going to brake something. Will I need to disconnect the shifter cable then remove the nut?
Old Aug 23, 2012 | 12:51 PM
jmd's Avatar
jmd
disconnect the shift cable bits.
grab it with pliers
unbolt it
wiggle it off
Reddeath210
Oct 6, 2015 08:20 AM
formula_novice
Aug 18, 2015 08:48 PM
86White_T/A305
Aug 17, 2015 12:16 AM
MENINBLK
Aug 5, 2015 11:58 PM
