vibration problem!
Old Feb 25, 2012 | 09:46 PM
91formula5speed's Avatar
Car: 1991 formula/83z28
Engine: 350/ 350
Transmission: wc t5/ non wc t5
Axle/Gears: 3.42/3.73
vibration problem!
My 83 z28 has a t5 and vibrates badly above 60mph at all times. It's at its worst in neutral. It is slightly better under a hard load but still bad. I can feel it in the shifter not in the wheel. I need some help.
Old Feb 25, 2012 | 10:08 PM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Re: vibration problem!
Ujoints...
Old Feb 25, 2012 | 10:12 PM
irocarter's Avatar
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
Maybe check the driveshaft for dents or pull the driveshaft and check the yoke to see if there is any wear on the splines. It could also be the pilot bearing/bushing wore out. If it has a pilot bushing and not a bearing, it is sometimes hard to "eyeball"if it's bad because a lot of times the bushing will wear evenly. Also, if the pilot bearing/bushing is too far in the crank, it won't support the input shaft properly, creating a vibration and eventually causing transmission damage. Just some things to look at. Good Luck.
Old Feb 26, 2012 | 12:15 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Borrow the driveshaft from your other third gen. If it fixes it, you've narrowed it down.
Same for wheel/tire assemblies. " " " " " " " "
Then the T5. etc.
Old Feb 26, 2012 | 07:31 AM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Do you have a polyurethane transmission mount? I have a T5 and had a very bad vibration and had my driveshaft balanced twice. Vibration didn't go away. I bought a Spohn Top Gun driveshaft and vibration was still there. I swapped the polyurethane trans mount for a factory one and vibration disappeared. Apparently the poly mount was transferring the vibrations from the T5 to the body of the car.
Old Feb 26, 2012 | 07:40 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
^same as above poster. I had an energy suspension poly mount and had a terrible vibration. Replaced it with a stocker and vibration went away. I've really heard nothing good about them and vibration.
Old Feb 26, 2012 | 08:15 AM
skinny z's Avatar
[QUOTE=91formula5speed;5193863..... It's at its worst in neutral.QUOTE]
Here's the solution to my vibration problem. Your comment about the vibration being worse in neutral eliminates the driveshaft and tire balancing issues (unless you meant neutral at 60 mph).
https://www.thirdgen.org/forums/tran...vibration.html
Old Feb 26, 2012 | 11:45 AM
Engine: 350/ 350
yes I mean neutral at highway speed. The faster you go the worse it gets.
Old Feb 26, 2012 | 08:03 PM
Engine: 350/ 350
I changed the mount and it got better. But still there it almost seems as if it only does it in 5th gear. if ibrun 60 in fourth I don't feel it.
Old Feb 26, 2012 | 09:50 PM
jmd's Avatar
jmd
It could be the transmission. But I'd still do the driveshaft and wheels before going to the trouble of the trans. swap. So... you've got some work ahead of you. See post #4 and if it needs the rebuild, maybe consider a T56.
Old Feb 27, 2012 | 10:56 PM
Engine: 350/ 350
Very disappointing just got it and its a nice car. It had a poly mount but even with the factory it vibrates.
Old Feb 28, 2012 | 05:17 AM
pwdbychevy's Avatar
Did you swap driveshafts yet?
Old Feb 28, 2012 | 05:25 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
can you let me know the tracking number on the ecm and memcal I bought from you on the 8th? It should not take this long to come from indiana to colorado ?
https://www.thirdgen.org/forums/engi...-complete.html
Old Mar 1, 2012 | 12:24 PM
Engine: Lb9
Transmission: M20
Kennedy, are you going to reply or just rip me off ?
Old Aug 23, 2012 | 01:51 AM
Engine: 350/ 350
It turned out to be the rear end. The now has an Ls2 and a 6speed and on the first test drive the vibration was still there. Man I was pissed. 4th gen rear and its finally gone.
Old Aug 23, 2012 | 12:13 PM
jmd's Avatar
jmd
In most circles, that could be described as kharma.
Old Aug 23, 2012 | 12:53 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
I just swapped a T56 into my 87 Trans Am, and i'm getting a bad vibration as well. I've got a factory style rubber trans mount. Only thing is, the vibration is even present at idle. Idk if the flywheel is out of balance or what? The guy I got the trans from said that the flywheel had been resurfaced, and it had some drill marks on the back, like they balanced it, or at least tried to. I'm stumped.
Old Aug 23, 2012 | 01:54 PM
Engine: 350/ 350
Lsx hater I see.
Old Aug 23, 2012 | 01:59 PM
Engine: 350/ 350
@ pwd by Chevy your car is bad a**.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
