changeing gear ratio from 2.77 to 3.45.
Old Sep 20, 2012 | 02:30 PM
Glenn88Iroc88's Avatar
Car: 1988 iroc-Z 5.7l TPI
Engine: 5.7l TPI
I found a site online that supplies 9-bolt parts and the site says i will have to change my carrier to a 3 series if im going to change my ratio from 2.77 to 3.45. is this true?
Old Sep 20, 2012 | 03:16 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: changeing gear ratio from 2.77 to 3.45.
One BIG YES... 2-series (2:77) now will Not work wirh 3-series (3:45) gear.
Old Sep 20, 2012 | 03:26 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Yep change carrier and speedo gears in trans to make it all work correctly
Old Sep 21, 2012 | 08:09 AM
Engine: 5.7l TPI
Thanks you both for the input.
Old Nov 4, 2012 | 11:09 PM
KidwithIROC's Avatar
Car: 1989 Iroc-Z
Engine: 5.7 350 TPI
Axle/Gears: 2.77
Now I don't want to open a HUGE can of worms here, but I have a set on 3.70's working noisily with a 2 series carrier and a special shim behind the ring gear. Is this BAD? Perfect pettern, .014 backlash. I have yet to abuse the car with the new gears and we set them up last monday. I have yet to get solid input on the carrier setup
Old Nov 5, 2012 | 05:58 AM
Didn't know you could even get ring gear spacers for the 9-bolt; but if so, that opens up an alternative. Some people don't like those, as they put more stress on the ring gear bolts; but others don't have a problem with them.
In the past, as far as has been known around here, the only way available to get from a 2 series 9-bolt to a 3 series, was a 3 series carrier.
Are you sure you have a 9-bolt?
Old Nov 5, 2012 | 06:11 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
They do not make "thick" gearsets for theses like they do for the Dana's in the Vettes so you can use 3 series gears
on a 2 series carrier?
Old Nov 5, 2012 | 10:10 PM
Car: 1989 Iroc-Z
Engine: 5.7 350 TPI
Axle/Gears: 2.77
Yeah I'm sure. I put them in last weekend.
Old Nov 6, 2012 | 12:21 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Some carriers have only a small distance around them where the ring gear normally rides. If this is used by the spacer and the ring gear ends up un-indexed at it's centre, it has potential to be a problem.
Old Nov 6, 2012 | 12:28 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Unless Im remember my decimal places wrong, .014 backlash seems like quite a lot. 10 bolts seem to like backlash in the .008-.012 range I think. I found a 9-bolt manual that claimed 9-bolts liked .004-.008 ish range or so? I know it was considerably tighter which put me off a bit, wasn't really sure which number to aim for. When mine was put together the backlash was right at .007 or .008 and the pattern looked perfect so I decided that was where it was going to be.
It's noisy at 50+ mph, enough that its noticable, but not enough that I cant listen to teh radio and drown it out. It doesnt do it at normal around town and country road speeds, so I dont really mind much. As good as the pattern looked and given all the measurements worked out, Im thinking that's just as good as this one is going to get.
Old Nov 8, 2012 | 06:11 AM
.014" is a bit on the "alot" side but not out of the realm... remember, this is measured cold, but things "grow" when they get hot, so a certain amount of that will go away in actual use. It's better to have "a little" too much, than even "a tiny bit" too little, as too little will make the gears attempt to occupy the same space, and that's never a good thing with moving metal parts.
I've never seen or heard of either a ring gear spacer or the "special" extra-thick gears for a 9-bolt. This is th eonly person I'm aware of who has ever used one of these. I'm suspicious here.
That said, if it works, it works. Since 3.70 is 10 and 37 teeth, only 10 on the pinion, that ratio is GOING TO have a tendency toward being noisy; no way around that.
Old Nov 8, 2012 | 07:28 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I guess that could work. When i did 2.77 to 3.27 i got a used 3 series carrier. I didnt compare the ring gears tho to see if a spacer could work but i guess the theory is sound.
Hey there may even be a market for these spacers lol. My old 2 series was solid. Worked great. The used 3 series had worn cones and i lost most of the posi action after 2 yrs
I did 2.73 to 3.73 in my 10 bolt by buying extra thick ring gear for 2 series Carrier
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
Regal105
Aug 23, 2015 03:45 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
