how to set detent cable with carb
Old Nov 15, 2012 | 09:52 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
how do you set the detent cable with a carbed motor, im about to the end of motor swap now and went to set my tv cable like i did on my old v6 where you pushed the button on the cable, and pushed the cable slider back into the housing the pulled the throttle wide open to set it and the cable isnt setting.
Old Nov 16, 2012 | 02:36 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: how to set detent cable with carb
www.tvmadeez.com
Last edited by t-top havoc; Nov 16, 2012 at 02:44 PM. Reason: spellcheck on android!!!
Old Nov 17, 2012 | 06:30 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Have you got the correct TV cable adapter bracket on your carb?
Old Nov 17, 2012 | 07:56 AM
Engine: L31 350
yes
Old Nov 17, 2012 | 10:05 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
And the correct cable mounting bracket?
Old Nov 17, 2012 | 10:14 AM
Engine: L31 350
yes, Iv got the eldebrock adjustable throttle and tv cable bracket
Old Nov 17, 2012 | 04:33 PM
Car: '87 Camaro
The tvmadeez link has the info for Edelbrock crabs and Holley carbs.
Do you have the correct geometry corrector for your carb? This is different than a bracket that gets mounted to the rear of the carb to mount the cables to.
Old Nov 17, 2012 | 04:36 PM
Car: '87 Camaro
Can you post a pic of the carb set-up showing what you have mounted?
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
