700r4 pump interchange/swap
Old Nov 28, 2012 | 07:52 PM
jonarotz's Avatar
Car: 91 Z28
I have done a lot of 700s but I have never tried to interchange pumps. Basically I have an 86 700 that has a leaking pump so I need to pull the trans. Rather than mess with it I have a new auxilary vb pump I would like to slam in there. Information is kind of limited on swapping between non aux vb pumps and aux vb pumps. From what info I have found, it looks like all I have to do is plug the aux vb pipe hole and that's it...is it that simple?
Old Nov 30, 2012 | 11:39 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: 700r4 pump interchange/swap
no, it's not that simple. the aux pump does not have the feed hole for the forward clutch that the non-aux does. that is what the pipe is for on the aux. pump.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
jklein337
Sep 19, 2018 06:23 PM
spaigo
Aug 21, 2015 07:46 PM
formula_novice
Aug 18, 2015 08:48 PM
TreDeClaw
Aug 14, 2015 06:58 PM
