clutch switch problem
Old Jan 17, 2013 | 02:53 AM
69boss429man's Avatar
Car: 1984 camaro z28
Engine: 305 5.0l
Transmission: 5 speed
Axle/Gears: stock
so i have been looking just about everywhere for a clutch safety switch to replace my broken some what working one. i have tried google searching, hawks, napa, autozone, summit, classic industries, o riellys, and ebay. nothing is coming up. any suggestions??
Old Jan 17, 2013 | 04:02 AM
Pat Hall's Avatar
Re: clutch switch problem
You could give Ebay a shot. However, if you can't locate one, you can always just bypass the switch. All you have to do is jumper the 2 wires together, and it's bypassed. I wouldn't necessarily recommend bypassing it if you have a wife or daughter that drives the car occasionally, but if you're the only one who drives it, I'd just bypass the switch and be done with it. I did that to the switch on my 69 Camaro years ago, and I've never once forgotten to push the clutch pedal in before starting it! Btw, if you can't find the switch anywhere, and you definitely want one, I do have one on a set of clutch pedals somewhere in my garage that have a switch on them. PM me if you'd like to buy a used one. For that matter, the switch is pretty universal, so you could go to a junkyard, and get another switch off of quite a few different GM cars with a manual trans.
Old Jan 17, 2013 | 06:05 AM
Engine: 305 5.0l
Axle/Gears: stock
thanks im not real good with wires though but am willing to learn if i take a picture of the switch can you tell me how to bypass it?
Old Jan 17, 2013 | 06:41 AM
Take about a 4" long piece of fairly thick AUTOMOTIVE (not house) wire; crimp a male slide terminal on each end; and plug the harness into that, instead of the switch.
{Very bad pic I found somewhere on the Internet; do a better job than this, all it's supposed to show is the type of terminals you need}
DON'T CUT ANY WIRES!!!! Don't damage, alter, change, cut, splice, hack, strip, twist, or in ANY OTHER WAY, molest the original harness.
Old Jan 17, 2013 | 06:47 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Like this one?
http://www.ebay.com/itm/Airtex-1S519...item4d0872001b
Rockauto have the Airtex Wells # 1S5196 shown above listed as for a 87 , yours should be similar
Old Jan 17, 2013 | 06:56 AM
Engine: 305 5.0l
Axle/Gears: stock
It's that easy haha okay sounds good to me.
Old Jan 17, 2013 | 06:58 AM
Engine: 305 5.0l
Axle/Gears: stock
Originally Posted by vetteoz
Like this one? http://www.ebay.com/itm/Airtex-1S519...item4d0872001b Rockauto have the Airtex Wells # 1S5196 shown above listed as for a 87 , yours should be similar
Not exactly ill post what mine looks like when it's light out
Ghettobird52
Jul 5, 2024 11:18 PM
Bryan F
Aug 18, 2015 02:28 PM
Fronzizzle
Aug 9, 2015 01:15 PM
rsrmoore
Aug 7, 2015 08:44 PM
