T-5 to a T-56
Old Jan 28, 2013 | 10:26 PM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
T-5 to a T-56
Is a swap from a non world class T-5 to a T-56 a seamless, bolt on transition?
If not, how much $$$ and which additional parts are needed?
Old Jan 28, 2013 | 10:29 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: T-5 to a T-56
https://www.thirdgen.org/forums/tran...ap-thread.html
Not to mention a 1000 other posts on the subject
https://www.thirdgen.org/forums/sear...archid=5718233
Old Jan 28, 2013 | 11:14 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Re: T-5 to a T-56
t56, custom t56 crossmember(search), use stock pedals, stock master, and a 1988 Cavalier 4-cylinder slave, t56 conversion flywheel if you have a 2 piece rear main seal...
Old Jan 29, 2013 | 01:37 AM
Savage388's Avatar
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
Re: T-5 to a T-56
How did the cavalier slave work out? I read about it being a possible solution to doing fabbing one out of the T-5 slave.
Old Jan 29, 2013 | 04:50 AM
malcom2073's Avatar
Car: 1987 IROC-Z
Engine: 383ci SBC
Re: T-5 to a T-56
I keep reading on these forums that you have to replace the thirdgen pedals, master, and slave with the matching pedals, master, and slave that go along with the T56, is that not true? That's the main thing that's pushing me away from a T56 swap vs building up my T5, is that it requires fab work.
Old Jan 29, 2013 | 05:44 AM
Re: T-5 to a T-56
How do you get from this,
to this?
requires fab work
It's all unbolt and re-bolt. Only "fab" work in it is hack-sawing off a piece of sheet metal about ¾" wide.
Read the sticky on this forum and the one in the FAQ forum; do the search; then since that will take about a month to read, if there's ANY detail left that hasn't already been covered, ask a specific question about it.
Old Jan 29, 2013 | 08:22 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T-5 to a T-56
Bolt in fourth gen pedals (chop the accel pedal off) + 93-97 fourth gen hydraulics = good to go.
Use third gen pedals (longer travel of the master cylinder) + 93-97 fourth gen master & line with cavalier slave = good to go.
Third gen pedals with 93-97 hydraulics works. However, if the clutch release fork has excess travel, it may grind into the pressure plate and have other clutch release idiosyncrasies. Hence the solution of the Cav. slave as mentioned above.
Old Jan 29, 2013 | 08:55 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Re: T-5 to a T-56
Perfect!
Easiest way when coming from a T5 IMHO especially when you have a cage like I do. The custom line is also easy to make. Just seach my name. I have posted the part numbers several times...
PurelyPMD
May 5, 2016 04:57 PM
tonys91rs
Oct 10, 2015 03:31 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
