question about 4th gen rear on a 3rd gen
hey guys i have a 85 z28 camaro on the trans am honey comb rims, i m thinking about doing a 4th gen rear. now i read it sticks out about 2 inches on each side. would i run into a problem with my rims?
Received 1,688 Likes
Re: question about 4th gen rear on a 3rd gen
No, the rims will be fine.
However, the tires may get cut by the fender; and your ego may suffer from people laughing at the "poseur" look of stock pizza-cutter wheels stuck way out in space and leaving VAST empty space inside of them. It's ... not an attractive look. But, easy to fix; just bolt on a set of 4th gen or Vette wheels. You'll need spacers for the front; around 1½" - 2" depending on the wheels you get.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
You won't get laughed at, except by sofakingdom maybe. The wheels setting out look better than being tucked in so far that they are narrower in track width than the front wheels.
1 Post
Car: 1991 Z28 1LE
I run a narrower/taller tire 225-60-16 with 1.75" spacers up front and love the stance and wheel gap.
If I ever have some disposable income and nothing else to do with it I'm going to commission these guys to widen 2" to the inside and start running a 265 tire in the rear.
http://www.weldcraftwheels.com/index-1.html
But yes occasionally I catch the wrong angle and think, "did I make a mistake going with this rear?" I just picked up a stock 92, and I can't tell you which one I prefer with the wheels about even with the fenders or with them sunken in...
So Mc, post up a pic of that car from STRAIGHT BEHIND from about 20 - 25' away, with the camera held low (12" off the ground or so), and the car pointed into the light.
Car: 89 RS
Engine: Stock L03
Transmission: Stock T5
Axle/Gears: Stock, Too high
Appears that it does, the wheels use a totally different offset/backspacing from the 3rd Gens, should require spacers up front to look right.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
