A question about 700R4 convertor lock-up.
Old Apr 2, 2013 | 03:53 PM
Cosmik Debris's Avatar
I had my 700R4 rebuilt with the nice strong parts and a Transgo kit. It works very nicely. When the shop installed the Transgo kit it allowed the transmission to lock-up mechanically somehow. I think this method was used on some trucks fitted with 700R4s. It works OK but now I am installing an aftermarket EFI system, and it has the ability to control the lock-up via the original solenoid. Can I change the transmission back to electronic lock-up easily?
Cheers.
Old Apr 2, 2013 | 04:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: A question about 700R4 convertor lock-up.
Possibly, or the two aren't mutually exclusive.
Old Apr 3, 2013 | 04:16 PM
Does anyone know how the Transgo kit achieves lock-up?
Old Apr 3, 2013 | 05:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
AFAIK the TransGo kit doesn't touch lock-up at all.
Old Apr 3, 2013 | 08:14 PM
Yeah it does. http://transgoonline.com/products.ph...dcountview=Yes
This states it allows lock-up with no wires. I guess I should ask them :-)
Old Apr 4, 2013 | 06:31 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Transgo makes a TCC control valve that operates the TCC by pressure alone. To convert to electronic TCC control, you just need to switch back to the factory style TCC control valve train that works with the solenoid. Then you need to be sure that the 4th gear pressure switch and the brake TCC off switch are in place. Your after market ECM, if it's like the ACCEL DFI will activate the TCC, when the 4th gear pressure switch and TCC brake switch are closed) based on throttle position and engine rpm.
BTW, The Transgo TCC control valve is separate from the other Transgo shift modifications. Removing it will not affect your shifting.
Old Apr 4, 2013 | 07:42 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by ASE doc
Your after market ECM,will activate the TCC, when the 4th gear pressure switch are closed.
Would that not give lockup in 4th gear only?
Not during the gears to prevent TC slippage like the OP wants?
Old Apr 4, 2013 | 09:44 PM
OK thanks, that's what I needed. I guess I can do all this through the bottom without removing the trans.
Old Apr 5, 2013 | 12:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Is their TCC valve very different from a factory non-computer one?
Old Apr 5, 2013 | 12:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Is their TCC valve very different from the factory one? If not then the hydraulic and electric controls can co-exist, like the factory did on non-computer setups. The valve will control minimum lock-up speed and the electric controls can handle other conditions.
Old Apr 5, 2013 | 04:10 PM
This is what I was hoping.
Old Apr 9, 2013 | 02:28 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
I believe that the Transgo setup is intended as a a simple option for 700R4 swaps into early vehicles with no other simple way of controlling TCC lockup. I am pretty sure that the Transgo setup only provides TCC lock up in 4th gear. As far as providing lock up in lower gears, remember that TCC lock up is intended for reducing trans temps and fuel consumption in cruise conditions. I have never seen any OE vehicle that allowed lock up lower than 3rd(direct drive) gear. I would be concerned having the TCC lock up in lower gears that it might be hard on the gear train and also on the TCC itself.
With electronic TCC control, especially with an aftermarket EFI system, you could easily set the TCC to lock up in 3rd gear as well as 4th. It would be a matter of installing the right combination of pressure switches. On my ACCEL DFI system, the ECM activates the TCC above a given throttle position and a given engine rpm. The 4th gear pressure switch is what prevents the TCC from engaging in any gear but 4th. To allow the TCC to activate in a lower gear, I would simply need to add a pressure switch to the 3rd clutch circuit.
Old Apr 9, 2013 | 04:42 PM
The Accel DFI system is the one I'm installing. I was hoping that the solenoid and wiring inside the trans were still connected and all I would have to do is hook up the new ECU to the standard plug.
I had a feeling that the transmission shop said they had replaced the valve body to one that allowed mechanical lock-up, does that make any sense?
Old Apr 9, 2013 | 05:41 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Logic would say not if the TCC was converted to full mechanical operation
Makes perfect sense
In that case you would probably need to install a stock VB to achieve the stock elec control setup what you want
There are several on the C4 forums with drag cars that lock the convertor when they hit 2nd.
Report quicker ET's from reduced slippage
Not wishing to risk it I had the lockup completely removed from my race T700
Old Apr 9, 2013 | 06:01 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Whether the TCC can easily be converted back to electric control would depend on what was done to make it mechanical.
I read an artcile about using early TCC engagement for faster ETs. Dana at Probuilt suggests that it be done only with the three clutch TCC as a stock TCC will not hold up under this kind of use. He also has found that with a converter correctly matched to the vehicle, there is no need for this.
Old Apr 26, 2013 | 10:35 AM
smolek37k's Avatar
Car: 95 MC Z34, 93 Caprice LTZ L05
Engine: 3.4 DOHC, 5.7L TBI
Transmission: Auto, 700R
Axle/Gears: ???, 3.08
Hello,
I have a 1993 Caprice with the 700R and when I wanted to delay TCC lockup on my trans I used the Jet Performance TCC lock up delay module #61640. So far ok.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
