Method for TC Lockup Using NC 4th Gear Press Sw
Old Apr 16, 2013 | 09:48 PM
F41eatsFords's Avatar
So I just bought an 86 Z28 (LG4, 700r4), and one of the previous owners converted it to non-cc q-jet ad distributor, so it got me thinking about TC lockup, since the ECM is disconnected. Since it's an 86, it SHOULD still have a NC 4th gear Press Sw (please correct me if need be). So, if this is the case, I came up with a method for TC lockup without dropping the trans pan for those of us who may not want to mess with it.
Here's the diagram I came up with for anyone else who may be interested. This can be added to existing info found here on TGO; sorry, I don't have the other wiring info sitting right here, and time is a little short for me as of late, but if anyone wants to add to this (links, etc), feel free. You should be able to do this with existing harness parts, a pressure switch (Normally closed), and a Normally closed relay. Hope this helps!
Attached Thumbnails Method for TC Lockup Using NC 4th Gear Press Sw-tcc-lockup-diagram.png
Old Apr 16, 2013 | 10:07 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Method for TC Lockup Using NC 4th Gear Press Sw
If you swap the NC 4th gear switch for a NO version you don't need the relay.
TCC will engage any time trans goes into 4th
https://www.thirdgen.org/forums/carb...c-control.html
Old Apr 16, 2013 | 10:13 PM
Yep, I've gone over all that before; Just figured I'd post another method for those who don't want to drop the pan for whatever reason. Better too much info, even if it's never used.
Warlocksirix
Sep 3, 2015 12:26 PM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
dhonda200
Aug 11, 2015 11:50 PM
