trouble with 700r4 after rebuild
Old May 21, 2013 | 02:34 AM
IrocZTPI's Avatar
Car: 1990 Camaro Iroc Z
Engine: 5.7L TPI
i had the tranny rebuilt and after about a month the car started not shifting out of 1st or 2nd and i got in it today and it did the same. I drove down street to the end of road about 1/2 mile the speedometer was bouncing. When i stopped i turned and had to back up put it in reverse and went back about car length or so and put it in drive and when i started driving back up block it shifted to all gears. Then came to stop and took off and it wouldnt shift unless i went in reverse and didnt let car shift out of second? Im puzzled at this one please
Old May 21, 2013 | 09:29 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Re: trouble with 700r4 after rebuild
Maybe a bit of dirt in the valve body or sticking check ball? I had a similar problem after a rebuild. Take it back to the shop that did the rebuild and explain the problem. They should have given you some kind of warranty.
Old May 21, 2013 | 09:46 AM
IrocZTPI's Avatar
Engine: 5.7L TPI
thanks would a bad speedo sensor cause that
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
HikoriYami
Sep 21, 2015 07:11 PM
WhteRbt
Sep 21, 2015 09:48 AM
eduardosac
Sep 16, 2015 02:18 PM
