another 700r4 question
Car: 91 rs camaro
Engine: chevy 355
Transmission: automatic 700r4
Axle/Gears: 410 gears
i put my motor and trans in my 91 rs 2 days ago. one issue is the radiator doesnt seem to fit right. after looking around i saw most people have a transmission cooler behind the radiator. should i have a transmission cooler for an automatic 700r4. i was told when i bought it its an 86 700r4.
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: another 700r4 question
Yes you NEED a trans cooler.
Im guessing your radiator doesn't have trans cooler built in.
If not, you will need to go with an aftermarket unit.
It's up to you if you put it ahead or behind the radiator.
Car: '87 Camaro
Why doesn't the rad fit? Do you know if its aftermarket & what brand?
Size & row count?
Size & row count?
Car: 91 rs camaro
Engine: chevy 355
thanks ttop and im guessing it didnt fit right because theres no transmission cooler behind it, and its the stock radiator for the car. its really clean though. would you suggest getting a different one? i just want to cruise this summer! ive been building this motor since i was 16 with my dad. i first had an 81 camaro that i shouldve neer gotten rid of, then i traded it for a 1967 c-10 short bed step side which i then sold for an 89 firebird which i recently sold for my 91 rs...needless to say im 23 now and i need to drive this car this summer or ill go insane
Car: '87 Camaro
Can you post a pic of your radiator?
If it's original // stock replacement it should have built in cooler.
( edit )
Pic from the back side of rad, passenger side
( edit )
Iroc8t8
May 4, 2026 08:09 PM
