700R4 whats this plug for ?
Car: 89 camaro RS convertible
Engine: 305 tbi
I have had 8, 3 gen camaro over the years all 87 and unders and all t5. I just got back in to camaro's about 5 days ago i got a 89 rs convertible for next to nothing. It is a 305 tbi 700r4 unmolested bone stock. As i was doing a tune up and a lock over i saw this plug just hinging down cant find out if it goes any where or not. I am pulling no codes. pilg has 2 wire brown and yellow. I have never had a 700r4 so i did not know. ?[ Sorry for the bad picture all i had was my 3 year old cell.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: 700R4 whats this plug for ?
If it's a four prong plug it goes into the trans for the fourth gear switch and TCC lockup.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I see purple and yellow, That would go to the vss.
I was thinking, perhaps erroneously, that the electric speedo started in 90 on the Camaro with the exception of the Berlinetta? Also would the speedo being unplugged pull a code on the TBI? I know it will on the CCC.
Anyway, if you see purple and yellow you have better eyes than me.
Car: `86 SS / `87 SS
Yes.
No kidding.
Engine: 305 tbi
Could be purple but looks brown i will have to look again. I do know the other one is yellow. and there is 2 wires not 4.
Car: 87 iroc-z
Engine: 454
Transmission: th350
should only be able to plug it into one spot. probably take longer to jack the car up then figure out where it plugs in on the tranny.
Engine: 305 tbi
YOu know i looked but could not find it but my light was running down so it was a bit dark i will look again tomorrow.
Engine: 305 tbi
Camaro through 1989 with speedometer cable doesn't have a VSS mounted at the transmission tailhousing. 1990 and later did.
Pretend someone repaired the car with a `Bird harness or one from a 90 Camaro.
The stock VSS is an optical sensor in the head (guts) of the speedometer and wires that go to a small in-line box, then off to the ECM. All under-dash.
Car: check
Engine: check
Transmission: check
Apparently GM used the same wiring harness in the Firebird's as the Camaro's. If it was a Firebird that connector would go to the magnetic VSS. Camaro's didn't get the magnetic VSS until the '90 MY.
RBob.
RBob.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
