9 bolt swap help!!!
Old Aug 20, 2013 | 06:13 PM
chrisvanguitar5's Avatar
Car: 89 Trans Am GTA
Engine: 5.7 L98
Transmission: 700 r4
9 bolt swap help!!!
Hey I finally found a 3.27 9 bolt for my 89 GTA, it came with the entire rear end. So now I need to swap my housing out and throw this one in?
Anyone ever done this, I am assuming its not that difficult. I also was wonderring about how long this one will last at 15 - 20 ft lbs torque on the posi, cones aren't mint but its way better than not being able to move!
Old Aug 27, 2013 | 08:37 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Re: 9 bolt swap help!!!
It's straight forward, Remove old one and put new one back in, Change teh fluid and hope for the best. I am unsure on your torque question.
Old Aug 28, 2013 | 01:13 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
What's in there now? A 10 bolt? Worn out 9 bolt? Swap the whole axle or just carrier? If you mean 15-12 lbs torque to overcome the posi that's not close to enough. Need about 35 ft lbs minimum. If you need to rebuild there are several threads. Look at the faq boars and search.
Old Aug 29, 2013 | 02:48 PM
IROZINCO's Avatar
yes, it would help if you specified what you were replacing. 9-bolt, for 9-bolt is not that tough, but make sure you use correct fluid and shim it properly. 10 bolt and 9 bolt parts are not interchangeable AT ALL. Even the axles are different.
1984HO
Mar 19, 2021 11:59 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
theurge
Aug 21, 2015 12:46 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
