need help on 9 bolt rearend left axle seal
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: need help on 9 bolt rearend left axle seal
https://www.thirdgen.org/forums/tran...urces-9-a.html
Here ya go. A thread i did a year or two ago. Also you will need new wheel bearings if your seal is leaking. They are in there too. I would just bite the bullet and replace both sides. If one is leaking chances are the other is not far behind.
Car: `86 SS / `87 SS
1992 Trans Am
May 10, 2023 07:19 PM
red90IROCls1
Aug 25, 2015 06:56 AM
