corvette servo????
Old Sep 11, 2013 | 12:15 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
corvette servo????
im a complete noob when it comes to auto trans. but heres my question. the trans shop called me to ask if I wanted a "corvette servo"?? ok, went for it ,but it got me wondering ,,how is it different than a stock"camaro" servo?? what does it do differently than the stock one??
Old Sep 11, 2013 | 12:19 AM
FryeDaddy's Avatar
Car: 85z28(sold),91 rs, 15'Mazda3GT
Engine: 5.7L V8 350 (ZZ4)
Transmission: 700r4 rebuilt with kits+ vette serv
Re: corvette servo????
From what I heard it helps makes it shift smoother, but again I'm a noob as well and just spend money because it sounded better lol.
Old Sep 11, 2013 | 01:03 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
It should have a alittle firmer shift than before
Old Sep 11, 2013 | 03:30 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Heres a link showing the Corvette servo installation = http://sethirdgen.org/servo.htm
I’m sure it depends in the transmissions condition when you have it installed but "I" installed one in mine and it made a large difference in the way it shifted. Nice and firm. You can definitely feel it when it shifts and probably the best part about it is launching the car from a stop at WOT and my car will bark the tires from 1st to 2nd and chirp them from 2nd to 3rd. Nice pull that definitely got even better with the 3.42 and Eaton posi install. I don't need a shift kit. Im very happy with it.
Old Sep 11, 2013 | 02:55 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
ALL wrong. The 'vette servo gives more holding power. That's it. Any other results experienced are effects of that.
Old Sep 11, 2013 | 04:57 PM
Engine: TBI,5.0
Sorry but I don't understand what part is wrong. Is it my reply ? Or one of the others ? Please explain.
Old Sep 11, 2013 | 05:53 PM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Straight from Hotod magazine write up.
Servo Assembly
The 2-4 servo assembly applies the 2-4 band. Upgraded servo assemblies have more surface area and volume to increase the holding force and yield firmer shifts. The best GM servo was used on C4/C5 Corvettes, as well as '93-and-later Camaros and Firebirds equipped with LT1 and LS1 engines. TCI sells the Corvette servo assembly under PN 376003. Aftermarket Super Hold servos are available with even more holding power. Changing the servo should be coordinated with valvebody recalibration, all matched to the intended application. Production inner (second apply) and outer (fourth apply) servo pistons can even be mixed and matched to fine-tune the feel.
Here's the whole article
http://www.hotrod.com/techarticles/1...n/viewall.html
Old Sep 11, 2013 | 08:15 PM
Engine: TBI,5.0
OK, when they say firmer shifts they mean when 1st hits 2nd and when 2nd hits 3rd.
I can even feel it down shifting.
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
Dragonsys
Sep 25, 2015 03:51 PM
italiano67
Sep 22, 2015 08:42 AM
