700R4 Info Needed Please
Old Sep 20, 2013 | 06:50 PM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
So I've never owned one and am in the dark here......
I bought my 88 GTA as a roller, Had the 305 T5 combo in it. I'm installing a built 76 carb 350 and have a long shaft built TH350 to handle the engine, After reading on here I decided a 700R4 would be a better choice for highway driving to car shows.
Can someone tell me what the function of this big switch is ?
I'm pretty sure this ones for downshift and TC lockup right ?
Will this VSS work with all the T5 components that's in the car ?
And lastly...... Since this car is set up for a T5, What would I need or have to do to make it function properly ?
Thanks !
Old Sep 20, 2013 | 07:13 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 700R4 Info Needed Please
Looks like you have a 4L60E ,
the electronic version of the T700 /4L60 that requires a computer to control it.
For your use you need to find the correct version trans that has TV cable ( looks like a kick down cable ) on the pass side where the plug you show is
Old Sep 20, 2013 | 08:34 PM
Restrorob's Avatar
Car: 88 GTA
Thanks vetteoz, No big deal.... I'll just sell this one and get one with the TV cable, But..... How will the TC lockup function work on the older 700R4 installed in my car ?
Old Sep 20, 2013 | 10:29 PM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
You can buy a kit to wire up the lock up to a switch in cab. I have one on my 90 700 r4, lock up is only in 4th gear and when switch is on.
Old Sep 22, 2013 | 04:24 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Many options
a manual switch on the dash as above
a vac operated switch
or a 4th gear switch inside the trans that will engage the TCC anytime the trans goes into 4th gear without any external input
The convertor releases as soon as trans downshifts or you brake
Old Sep 22, 2013 | 06:56 PM
Restrorob's Avatar
Car: 88 GTA
Thanks, Can you give me more info on this style switch ?
Like where to get one and is this something I can install myself without a total trans tear-down ?
Old Sep 23, 2013 | 03:18 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
On ECM controlled cars there is typically a 4th gear switch (N/C ) in the valve body ( accessed by dropping the trans pan ) that gives 4th gear indication to the ECM.
You swap that to the N/O version and rework the internal wiring depending on what type solenoid you have so the external 12V supply either ;
goes through a 2 terminal 4th gear switch to ground through the solenoid
or through the solenoid to ground through a single terminal switch
Everything you need to know about TCC control here
https://www.thirdgen.org/forums/carb...c-control.html
As yours is a stick car you will obviously have to run a new fused supply for the lockup through a brake switch to the correct terminal
on the connector ; drv side of trans
as well as extending the backup light wires from under the car back into the interior to connect to the switch at the base of the shifter which also has the P/N switch.
Old Sep 23, 2013 | 06:38 AM
Restrorob's Avatar
Car: 88 GTA
Thanks alot vetteoz......
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
TreDeClaw
Aug 14, 2015 06:58 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
