700r4/torque converter question
Old Oct 13, 2013 | 02:22 PM
andrewdains's Avatar
Car: 1984 Camaro Z28
Engine: 350 sbc
I have an 84 Camaro with what I believe is an 87 350 4 barrel carb 2wd set up in it, I rebuilt the top end and put a new cam in it, and it drove fine(ish) for a month, then I started have problems. anytime I get back about 30% throttle in drive, it starts running rough, sputtering, coughing, almost like the timing goes out, but when I put it in neutral or reverse, it runs fine....I have a Holley 670 street avenger carb on it, so I'm not sure what the hell is going on with this, my buddy says it might just be the torque converter, but I'm not sure....any ideas or insight would really be appreciated!
Old Oct 13, 2013 | 02:51 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 700r4/torque converter question
If it was the torque converter then you would have the exact same symptoms in reverse as forward.
Old Oct 13, 2013 | 03:05 PM
Cosmik Debris's Avatar
Highly unlikely to be the torque convertor. Check plugs and wires first. Do the timing and checkout the carb.
Old Oct 13, 2013 | 05:19 PM
Engine: 350 sbc
I rechecked the plugs and wires, number 5 plug was clean, compared to the rest of the plugs which we all pretty black....so why would the engine run fine in neutral and reverse, but as soon as its in drive, start missing? Do I need to work on the carb tune?
Old Oct 13, 2013 | 05:36 PM
Engine: 350 sbc
I'm starting to think less and less that its the torque converter and more that its a carb issue. I haven't heard very many good things about the Holley Street Avengers and that's what I'm running.
Old Oct 13, 2013 | 06:08 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Less /no load on the engine.
Until you can pin point your actually problem ,( it may well be a spark related problem ) you need to work on everything.
For starters , why do you have 7 dirty and one clean plug ?????
Given the design of a carb intake , is highly unlikely that is a carb ( fuel ) problem so why are 7 cylinders not firing properly
( which would give exactly the rough running cond you describe.)
start a question in carb dept
Old Oct 13, 2013 | 06:28 PM
Engine: 350 sbc
will do
Old Oct 14, 2013 | 03:30 PM
An engine running fine under no load and spluttering or mis-firing under load is usually a good sign you have a problem with your spark. Old hot-rodders used to say 90% of all carburettor problems are electrical :-)
Old Oct 14, 2013 | 03:44 PM
Engine: 350 sbc
I believe your right, 7 of the plugs were pretty black, #5 plug was clean...
Old Oct 14, 2013 | 05:11 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
As your problem is not trans related should close this and start a new post in the Engine dept
As you have one good plug ( indicating good spark from the coil ) as Cosmik Debris said in post # 3 ,I would be checking the plugs and the wires first
http://www.wikihow.com/Test-Spark-Plug-Wires
Ohm test each wire , the wires break down with age and while you may observe a visible spark at the plug with it out of the engine
it may not have enough grunt to fire in place when covered in fuel
http://www.autotips.com/plugwire.htm
Old Oct 14, 2013 | 05:17 PM
Engine: 350 sbc
how do I close the thread?
Old Oct 14, 2013 | 07:00 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Stop responding here and start a new thread in a more relevant dept
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
