Switch Starter with T-56 Conversion
Old Nov 19, 2013 | 02:23 PM
irocdis's Avatar
Which Starter is better with T-56 Conversion in 88 Iroc.
153 tooth original 305 3rd gen style starter?
or
4th gen starter?
Old Nov 19, 2013 | 02:51 PM
Twin_Turbo's Avatar
Re: Switch Starter with T-56 Conversion
LT1 corvette mini starter, never look back
Old Nov 19, 2013 | 04:17 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
All 3 work.
sounds cooler than:
4th gen starter?
which is lighter than:
If you try hard enough, either of the first two can be had online for under $150 outright.
Old Nov 20, 2013 | 08:18 AM
irocdis's Avatar
Originally Posted by jmd
All 3 work.
sounds cooler than:
4th gen starter?
Which one is easier to wire up?
Old Nov 20, 2013 | 04:55 PM
jmd's Avatar
jmd
The blue one.
Old Nov 20, 2013 | 08:30 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
What they are trying to say is buy any LT1 based starter. So basically order one for a 93-97 camaro or firebird with a 5.7 LT1. The wire will be the same as the stock 3rd gen ones so no need to modify anything.
Old Nov 20, 2013 | 08:36 PM
Twin_Turbo's Avatar
I meant corvette LT1 ministarter, not the same as 4th gen F body. The vette starter is a nippon denso unit
Old Nov 20, 2013 | 08:49 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
It doesnt matter which starter you use as long as it's for an SBC with the right tooth count. I just use 4th gen F-body starters, but the corvette option is a good one also.
The newer 4th gen and Corvette starters are gear-reduction starters so they can turn the engine over much faster. Just makes everything easier, also since they're smaller and ligther you cut weight AND you get more header clearance.
tonys91rs
Oct 10, 2015 03:31 PM
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
