Changing pinion gear with ring gear?
Old Dec 29, 2013 | 02:46 PM
85Irocbuild's Avatar
Car: 1988 Gray Iroc
Hi all,
I am going to be changing my rear gear ratio from stock 2.73 to 3.42. I'm going to use my 2 series carrier and install the 3.42 ring gear onto it with a spacer. My question is, do I need to change my 2.73 pinion gear as well? Do all pinion gears work with any ring gear, as long as they have correct spacing? Also, is there any reason the axles would need to be changed when going from 2.73 to 3.42? I am new to this, so thanks for the help.
Old Dec 29, 2013 | 02:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Changing pinion gear with ring gear?
Ring and pinion gears are always matched sets you can not interchange them with any other gear even if its the same ratio. You must change both.
Axles are not affected.
Old Dec 29, 2013 | 04:31 PM
Car: 1988 Gray Iroc
Got it, thanks for the response.
Old Dec 29, 2013 | 07:40 PM
big gear head's Avatar
You might want to read this before you get started. https://www.thirdgen.org/forums/tran...axle-gear.html
Also, I strongly recommend getting a 3 series differential or a special thick 3.42 gear that is made to fit the 2 series differential. Using a ring gear spacer in the 7.5 rear end is a very bad idea.
hectre13
Dec 11, 2023 08:14 AM
jklein337
Sep 19, 2018 06:23 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
