t56 clutch issue
Old Jan 19, 2014 | 01:01 PM
irocdis's Avatar
t56 clutch issue
I having an issue with clutch engament on my t56. I recently did a conversion on a l98 auto to a t56 pull style clutch. I put a new stage 2 competion clutch and it engages really high ,right at the end of the pedale. I remember reading a post that by changing the slave you can bring engament point down. I think the slave was off of a 88 cutlas cali. Can I use a adjustibale master slave from tick performance to accomplish the same thing?
http://www.tickperformance.com/clutch-hydraulics-1/
Old Jan 19, 2014 | 01:10 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Re: t56 clutch issue
there are multiple threads on this matter. some people opt for the adjustable master while others opt to use the cavalier slave as you mentioned. my preference was to use the cavalier slave and be done with with but the chioce is yours to make
https://www.thirdgen.org/forums/tran...ew-clutch.html
Old Jan 19, 2014 | 05:41 PM
irocdis's Avatar
Thank you for the info. If I go the 88 cavalier route how can you bleed the slave? Its just the slave you change right not the Master. The master stays stock 4th gen?
Also was anyone try the McLeod adjustiable master?
http://ls1tech.com/forums/manual-tra...-13-16-mc.html
Will this even fit a 3rd gen, looks pretty big.
Old Jan 20, 2014 | 01:51 PM
irocdis's Avatar
Ok I order Dorman# CS360002
88 cavalier 6 cylinder slave. Looks to be same part# as 4 cylinder.
Old Jan 20, 2014 | 05:21 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I dont know about that one, but I know the Tick one fits, and they may be the same part.
19irocz85
Aug 31, 2015 10:31 PM
19irocz85
Aug 26, 2015 07:54 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
86White_T/A305
Aug 17, 2015 12:16 AM
rsrmoore
Aug 7, 2015 08:44 PM
