Can you improve the shift quality of a stock T5?
Transmission: World Class T-5
Axle/Gears: BW 3.45
I have two T5s. The WC one on my low mile '89 shifts fantastically. Precise, buttery smooth, etc.
The NWC T5 which was transplanted into my '83 requires more effort to shift and is a bit more notchy. I'm okay with that, but what bugs me, is that it is also a bit recalcitrant about being downshifted into 3rd. Upshifting into 3rd is okay, downshifting into 3rd is a problem though.
I was thinking about going with an aftermarket shifter, but before I do that, I was wondering if there is anything I can do to improve shift quality and precision with the stock piece?
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Can you improve the shift quality of a stock T5?
Have you checked or changed the fluid?
I have noticed the NWC is a little more notchy mostly when cold. I believe it is because of the thicker gear oil and maybe because of the different syncros.
Axle/Gears: BW 3.45
The notchiness is an acceptable given when compared to a WC. It's the downshifting into 3rd which bugs me.
Axle/Gears: BW 3.45
https://www.thirdgen.org/forums/faq-...t5-fluids.html
Axle/Gears: BW 3.45
Yeah, I wonder if something like Lucas Transfix would make a difference.
Car: `86 SS / `87 SS
If your downshift into 3rd is not speed-matching the gear after a fluid change, it may just be time to go go through the box.
If the blocker friction surface is worn and the blocker ring bottoms out before your shift can put effective pressure into the blocker grabbing the gear cone, it's not going to shift "nice."
Even if the clutch is properly releasing.
Axle/Gears: BW 3.45
Disregard the red markings.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
NWC as it has brass syncros. And yeah, ATF all years but NON-synthetic. NWC brass doesn't like it.
Downshift issue does sound like you need a rebuild though!
http://lugnutz65chevystepside.weebly...n-rebuild.html
Axle/Gears: BW 3.45
If it ends up that it needs a rebuild, (I haven't driven it lately, it's in winter sleep), I think I'll probably just try to find a functioning WC T5 instead.
I would still do a pedal down rpm test in 1st to verify the car stays still / the clutch works.
Axle/Gears: BW 3.45
Explain that test to me. Just rev it in 1st with the clutch pedal depressed?
BTW, clutch is brand new.
Linson
Aug 21, 2015 02:12 PM
dhonda200
Aug 11, 2015 11:50 PM
