Dumb question: Where does torque arm connect?
Hey folks -
I have a car I'm building from scratch that didn't have anything (just a rolling chassis).
This '88 was originally a manual, and I couldn't afford to do a T56, so I went to a 700R4 auto trans.
I'm just about done buttoning things up, but I don't know where the front part of the stock torque arm connects. Is it supposed to connect to the transmission? If so, and I'm using the original one from the manual transmission, do I need a different one?
Thanks, guys...
Thanks, guys...
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Dumb question: Where does torque arm connect?
No. IIRC, however, the torque arm mount is different between auto and manual.
Here we good:
http://www.hawksthirdgenparts.com/pr...olts-Used.html
JamesC
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Yes, auto and manual are different mounts.
Is the 700r4 from an f body ? If not, it won't have any place to mount the torque arm.
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Hmm... I hope I'm not in trouble here.
I originally had no engine, no trans, just a body and four wheels.
I built up the engine for an auto trans, and bought a 700R4 from craigslist (with the assumption that I'd rebuild it). I never knew or thought about the trans having to be from a Camaro. :-(
In any case, I realize now that I was missing the torque arm bracket for the trans. I just ordered one from ebay that is for both a 700R4 and third gen Camaros. Hopefully, it will bolt up to the existing 700R4. If not, am I left with having to get a new transmission from a third-gen Camaro?
Thanks for your help, everyone!
J
J
Car: 88 GTA
No, If your tail housing doesn't have the provisions for the torque arm mount bracket you can get a cross member such as this to use the trans you've got......
http://www.summitracing.com/parts/up...t/model/camaro
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
This is great info for those of us switching from auto to manual trans or vice/versa as in this thread.
The T56, who is it made by? I heard it can handle more torque from a modified engine.
Car: `86 SS / `87 SS
If you have the tail on the left and want to trade me for the one in the middle (allows stock third gen torque arm bracket to bolt-up) PM me:
The T56 was originally a Borg Warner design, first introduced in the '92 Viper, then '93 F-bodies. Tremec bought their light duty line in the 90s.
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
the middle one.
if it doesn't look like that then you can buy a trans crossmember with a torque arm mount built in. Problem solved. no need to by another trans or swap tail housings.
I think I might be in luck. I'm pretty sure I remember seeing 3 horizontal bolt holes.
I'll check when I get home later on.
I can confirm that I have the right transmission, and my bracket from ebay just arrived, and it appears to be correct for both my transmission and my torque arm.
My bracket doesn't appear to have the bolts, however (other than the LONG one in the middle). Anyone know what size/thread pitch I need to get at the hardware store?
Also - it looks like the bracket needs to be on the transmission BEFORE the trans is in place, as I can't seem to figure out how to get the bracket on without doing that. That seems weird that I would have take out the trans to put on the bracket, however. Ideas?
Thanks!
J
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
rudolphschenker
Sep 4, 2015 02:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
