Car on jacks, rotors wobble slightly
Old 03-29-2014, 01:24 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Like the post states!
I'm doing a brake job and noticed my rotors or axles have a slight wobble. Just wondering if there's an acceptable amount of wobble?
I noticed this a few weeks ago. I had a wheel sent out for repair assuming the wheel was not true.
Old 03-29-2014, 03:36 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: 383-Holley Terminator EFI
Transmission: 700R4 Pro-Built Street/Strip kit
Axle/Gears: Strange S60 3.55:1
Re: Car on jacks, rotors wobble slightly
Not sure how slightly is slightly, but the general rule of thumb would be if you can feel it, it's way past acceptable and just not right. Is this front or rear?
Old 03-29-2014, 03:47 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Rear
Slight is enough to see it at the rotor. I could roughly measure but I would guess 1/16"
Old 03-29-2014, 03:57 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Bent axle shafts could be a possible cause
Old 03-29-2014, 05:00 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Do you have lug nuts on? If not the rotors will move. If the nuts are on then it could be worn bearings. There could be no wobble you could feel but still have a bent axle. You'd need to measure the run out to be sure. More info. and/or a pic showing what exactly is moving may help.
Old 03-29-2014, 05:07 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Rotor moving in and out slightly. I could remove the rotor and caliper and run it that way too I guess.
Old 03-29-2014, 06:38 PM
joshc's Avatar
Car: 1986 Trans Am
A little in and out movement is normal. Every vehicle I've owned with "C" clip style axles has had in and out movement. 1/16th sounds normal.
Old 03-29-2014, 06:52 PM
Lurbie's Avatar
Car: 89 Camaro
In and out movement is normal. When you said wobble, I was thinking you could wiggle it, rock it back and forth and/or up and down.
Old 03-29-2014, 07:05 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Yes c-clips have that normal amount of play. When car is still you can either rock the car back and forth while its on the ground... You'll hear almost a clunk noise which is fine.
Just so were all on the same page, I used the term wobble but could also describe it as a small warp. (Rotors have just been machined/ resurfaced btw).
Are you suggesting this could be a normal amount of play caused by the c-clip?
I wish I had a video clip...
Frozer!!!
01-19-2024 04:55 PM
specialized
06-18-2022 09:26 AM
customblackbird
08-15-2021 10:16 PM
B_Dubya
08-26-2015 05:09 PM
Quick Reply: Car on jacks, rotors wobble slightly
