9 bolt blues
Old Mar 30, 2014 | 08:21 PM
baddone88ta's Avatar
Car: 1988 Trans am gta
Engine: 396 Stroker sbc
Transmission: 700r4 3000 stall
Axle/Gears: 9 bolt posi 2.77 gears
9 bolt blues
I purchased a gear set and install kit for my trans am back in january. I am finally ready to swap gears for what I thought was a 10 bolt but when I raised the car and tore the rear apart I found out it was a 9 bolt so now I have a new set of 3.73 gears and install kit for a 10 bolt and and nothing that they fit in. So my question is should I buy a series 3 carrier and new gears to get to 3.73 in my 9 bolt. Or swap to a 10 bolt?
Old Mar 30, 2014 | 09:10 PM
big gear head's Avatar
Re: 9 bolt blues
It would be cheaper to get a 10 bolt. Get a '90 to '92 with 28 spline axles. 9 bolt parts are expensive.
Old Apr 2, 2014 | 08:29 PM
Parrydise7's Avatar
Re: 9 bolt blues
If cost is a big concern that is something to consider. However, I don't think there are too many members on this site that would willingly trade their 9-bolt for a much weaker 10-bolt.
Did Dana 44s have ten bolts? If you have a Dana 44, shoot me a pm and I will be happy to take it off your hands.
Old Apr 3, 2014 | 07:13 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: 9 bolt blues
How do you know that your 9-bolt isn't already a 3 series carrier? Did you check?
You could always return the gear and install kit, and save that for 9-bolt parts.
Also, please fill out the rest of your profile so we don't have to ask you the basics about your car.
Old Apr 3, 2014 | 10:23 PM
Re: 9 bolt blues
When I ordered the gears and brg & shim kit I looked at the tag on the diff and found out that it had 2.77 gears. But I wasn't thinking about counting diff cover bolts at the time and assumed that it had a ten bolt posi in it. So knowing that it had 2.77 on the tag I ordered the thick set of 3.73 gears for the series two carrier. That was back in january so a couple of days ago I put the car on jack stands tore it apart and found out it was a 9 bolt. I called the place where I got the gears from and they said it had been to long and wont refund my money even though the boxes havn't been opened. So now a friend of mine has a ten bolt in a 91 camaro convertable and he will trade but I don't think that I will cause it has drum brakes and is a one legger. I think Ill try to sell the gears or maybe save them for later and just save up for some new gears and brgs for the 9 bolt.
Old Apr 4, 2014 | 07:10 AM
Re: 9 bolt blues
There are no thick gears for the 9 bolt. You will have to change the differential if you want to change the gears. The thick gears are going to screw you up on the 10 bolt unless you use a used Auburn, which is never a good idea. Looks like there is no good or cheap way out of this for you right now.
Old Apr 4, 2014 | 10:50 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
Just an FYI I have about $1000 in my 2.77 to 3.70 swap in my BW 9 bolt. The rebuilt carrier from 9bolt.com was almost 1/2 of it.
Huge improvement tho.
Old Apr 6, 2014 | 09:50 PM
Re: 9 bolt blues
I am just going to keep the 9 bolt and buy gears and carrier when I get the $$ saved up. At least I went through and checked it all out. Seem to be in great shape.
Old Apr 6, 2014 | 11:53 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: 9 bolt blues
Are you interested in selling the 10-bolt 3.73 gears? I've also got a 9-bolt series 3 carrier (3.27) I plan to rebuild and could sell you. Not sure when it'll be done but if you're interested I could hurry it up some. What make are the gears? Part number?
Old Apr 7, 2014 | 12:06 AM
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
Re: 9 bolt blues
Not to add salt to your wounds, it is always a good idea to inspect what you have before you order assume what you might have order parts.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
Gunsbee
Sep 7, 2015 07:10 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
