T5 VSS electric speedo driven gears
Old Jan 5, 2014 | 11:36 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, I'm looking to swap a t5 into my 91 bird soon, and the car has an electric VSS stock. I have 3.45 gears so that means (correct me if I'm wrong) I'll need the 20 tooth driven gear. I can easily find gears for the mechanical speedometers but I have no idea where to look to find the electronic driven gears (or part numbers at the very least). None of the stickies here are helping and neither are the searches. Any leads would be greatly appreciated. Thanks!
Old Jan 6, 2014 | 10:51 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T5 VSS electric speedo driven gears
I have made them from two good gears. Might have a 19 and a 22 in my parts. Will check.
Old Jan 6, 2014 | 11:10 AM
Engine: LB9
Thanks but after doing some research, I'm going to need the 20 tooth driven gear. My T5 already has a 22 tooth (came out of a car that had a 3.73 rear end).
Old Jan 6, 2014 | 12:42 PM
Engine: LB9
Well fortunately I found the part number for the gear, but no gear yet, it is 14090593, if anybody has any leads that would be MUCH appreciated!
Old Jan 6, 2014 | 12:50 PM
Engine: LB9
Honestly, on second thought, that 19 tooth that you may have ought to suffice. That's for a 3.42 rear end and it should be close enough. Let me know if you have it and how much, thanks!
Old Apr 6, 2014 | 09:08 PM
camaro211z28's Avatar
Car: 92 camaro RS
Engine: vortec 350/396
I got a 92 camaro pulled out 700r4 and put t5 in it. Had cable driven speed sensor. Pulled rhat out and found a electronic speed sensor out of a 92 v6 and it fit in my t5 and the teeth on the electronic sleed sensor is 18 teeth. Dont know if speedo will work or not. Havent put trans in car yet
Old Apr 7, 2014 | 12:05 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The teeth count on both gears has to be the same as what you had in the T700 for your speedo to be accurate
https://www.thirdgen.org/forums/tran...ve-driven.html
Old Apr 7, 2014 | 12:47 AM
Car: 92 camaro RS
Not sure what the teeth count was in the 700r4. But I took the gear off the cable driven speed sensor and put it on the electric speed sensor so I know the teeth are the same for the t5.. but not sure if they match the 700r4 teeth count. Are there different teeth count for the 700r4 or were they all the same?
Jorlain
Aug 24, 2022 05:11 PM
GTAman
Aug 27, 2015 10:29 PM
Dialed_In
Aug 20, 2015 01:45 PM
mizz0313
Aug 12, 2015 06:45 AM
