Differential and gear swap question
Old Apr 30, 2014 | 01:45 AM
Jake_92RS's Avatar
Car: 1992 Camaro RS, 2012 Camaro SS 45th
Engine: L03 305 TBI V8, Blown 6.2L LS3
Transmission: 700R4, TR6060
Axle/Gears: GM 7.6" 10 Bolt 2.73
Is there a good limited slip differential that I can swap in to my 92 Camaro RS w/ 305 and put a 3.73 gear ratio on as a direct fit? Right now it has the stock 2.73 gears and open carrier. Thanks
Old Apr 30, 2014 | 07:17 AM
big gear head's Avatar
Re: Differential and gear swap question
If you can find a used Torsen from a '98 to '02 it will work. Yukon makes a clutch type differential called the Dura Grip that is on the lower end of the price range. The Eaton Posi is a good one, but a little more expensive. Just don't use the Auburn or Eaton Governor Lock. Just be sure that you get a 3 series.
I'm assuming that you know that when you change gears you will have to set the pinion depth, bearing preload and backlash.
Old Apr 30, 2014 | 09:40 AM
graysmoke's Avatar
Car: 91 Convertible
Engine: Stock 305
Originally Posted by big gear head
Just don't use the Auburn .
I am in the process of getting a rebuild Auburn, why do you say not to get one?
Old Apr 30, 2014 | 01:02 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Auburn Gear (AG)
This is directly from Randys Ring and Pinion =
The Auburn Gear limited slip uses a cone style clutch that wears directly against the carrier case and provides the friction force to make the unit work. "This design is not rebuildable". Once the cone clutch or case wears out, the "entire unit" must be replaced. Even with this shortcoming, this design works well for occasional use where extra traction is needed. They have good impact strength in passenger cars and trucks up to 1 ton. They will hold up well to high horse power, but will not last long if there is a lot of tire spinning.
Here’s a link to his site explaining L.S.D.and Locker Carriers /Differentials = http://www.ringpinion.com/TechnicalH...ini-Spools.inc
Old Apr 30, 2014 | 03:25 PM
Auburn is the worst differential I have delt with in the 32 years that I have been building rear ends. They wear out quickly if you do burnouts, can not be rebuilt (shouldn't be rebuilt) and they fill the rear end with powdered metal as they wear, which runs through all of the bearings and gears, ruining them in the process.
Old Apr 30, 2014 | 05:02 PM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
I'm pretty sure I have an Auburn unit but how can I tell?
Old Apr 30, 2014 | 06:28 PM
5 coil springs in the center.
The Auburn is all right for a car that doesn't get abused. Many Auburn differentials have lasted for many years with no problems. If you like to do burnouts then the Auburn is definitely not for you. It would be my last choice for a limited slip differential.
Old May 1, 2014 | 08:26 PM
graysmoke's Avatar
Car: 91 Convertible
Engine: Stock 305
Jake, unless you plan on doing a cam swap, the stock rpm power band is too low for the 3.73 gearing and works best with 3.42 according to what I have read. After reading this thread I put a hold on getting the auburn and now looking at either a torsen or eaton posi(not gov lok)and 3.42 gears.
Old May 1, 2014 | 08:45 PM
Take a look at the Yukon Dura Grip too. It's a little cheaper than the Eaton Posi, and other than the clutch material it's the same thing.
Old May 7, 2014 | 02:21 AM
Jake_92RS's Avatar
I actually plan on doing a complete engine swap; A gen I 350 sbc.
Old May 8, 2014 | 12:00 AM
eli4084's Avatar
Car: 1986 iroc z
Engine: 305tpi
Transmission: i think its 700r4
Hey guys sorry to post on his thread I got a 86 iroc 305 but I want more take of I'm Perry sure I got 2.73s cuz my car does not jump at all I want more acceleration from the jump any advice
InfinityShade
Aug 22, 2015 08:00 PM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
mizz0313
Aug 12, 2015 06:45 AM
