9 bolt 3 series whining and loose
Old Oct 4, 2011 | 11:52 PM
unapez's Avatar
I have an 85 T/A, posi rear 9 bolt with 3 series carrier. It whines on accelleration / decelleration. I jacked up the rear and pulled the cover. With the car in park, I can turn the passenger wheel about 10 degrees before the opposite wheel gets engaged. I am new to the 9 bolts, but this sounds like there may be a spring inside that pushes the spider gears toward the center, between the outer cone and spider? If so, is my spring shot, the cone shot, the spider, or all of the above? The ring and pinion appear to be in correct tolerance. Old diff fluid had a metallic appearance so I assume something is wearing. Any help is appreciated.
A good photo of a dissasembled carrier or expanded view might help me too.
Old Oct 5, 2011 | 01:34 PM
geoffz28's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Axle/Gears: Moser 12bolt 4.10s
Re: 9 bolt 3 series whining and loose
The cones are easy to check. http://www.9bolt.com/technical.html
I think I have some detailed info the 9bolt regarding rebuilding etc saved somewhere on my computer. I will try and find it to see if it is what you are looking for.
Old Oct 5, 2011 | 01:44 PM
geoffz28's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
this is what I had saved on my computer
https://www.thirdgen.org/bw_9-bolt_cone_repair
I had this problem with the whining my 9 bolt though becuase of crappy contact pattern on the gears. Much louder on acceleration/highway cruising 60+kph (30-35mph)
Old May 6, 2014 | 06:01 PM
gallaire's Avatar
Car: 91 trans am
Engine: ?
Transmission: auto 4sp
Axle/Gears: posi
I can pull my axcle in out 1/4 inch what up what do I do
Old May 6, 2014 | 06:43 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I'll take a guess and say the diff needs to be rebuilt. That means new cones or machining the carrier halves and the cones plus shims to get things back to "new" condition. There are many threads on what needs to be done. Depends on your budget and mechanical skills how you go. Doesn't cost a bundle if you do all/most yourself. Especially if you know someone who can do the machining.
Old May 7, 2014 | 12:09 PM
keykey's Avatar
Car: 1988 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH700R4
Axle/Gears: 3.27 9-bolt w/ Torsen LSD
I just did this job on my 9-bolt and here is my thread with some pics: https://www.thirdgen.org/forums/tran...er-9-bolt.html
My oil was very metallic too, and it's from the cones wearing.
Old May 7, 2014 | 01:37 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
When I got my 9-bolt it came out of a car with 130k miles on it. Cones looked FANTASTIC. Oil looked like liquid mercury. It just happens I guess.
Old May 7, 2014 | 01:59 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Depends on how it was driven. The one I did had 120k and was totally done for. The oil took a long time to all ooze out.
Old May 7, 2014 | 02:50 PM
gallaire's Avatar
Car: 91 trans am
Engine: ?
Axle/Gears: posi
well Im mechanilly inclined just haven't done a lot of diffs so I need pull axcles do the bearing and the gears ?? how much in parsts
will it last if I leave it the way it is is it from drifting I like to drift lol
Old May 7, 2014 | 03:14 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
You need to open it up to be positive but from what you describe the posi needs to be rebuilt for it to work at all. You don't HAVE to do anything other than get new or machined cones and shim the spider gears if needed. You can machine a little of the noses of the existing cones if they aren't completely worn away but if you get new cones and they don't have the nose recess you'll need to get the carrier halves machined. There are threads and pictures galore but first is to pull the diff and see what you're dealing with for sure.
Old May 7, 2014 | 04:44 PM
gallaire's Avatar
Car: 91 trans am
Engine: ?
Axle/Gears: posi
I did pull my diff cover and took bolt off to take pin out off pinion its seems stiff im just stuck cus udno how much its gana cost and not 100 confident in doing the job if its 300 bucks maybe I wont. do u think it will last the summer with easy driving
Old May 7, 2014 | 06:54 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Axle/Gears: 9 bolt 3:23
If you've got a pin to pull it's not a 9 bolt.
Old May 7, 2014 | 07:32 PM
gallaire's Avatar
Car: 91 trans am
Engine: ?
Axle/Gears: posi
the diff cover has 10 bolts
Old May 7, 2014 | 07:59 PM
9-bolts have 9 bolts in the cover. They were last used in 89 model cars. (which is not to say that a 91 wouldn't have one, by now; only, it didn't come like that)
A rear with 10 bolts in the cover is a .... I'll let you do the math.
Old May 8, 2014 | 01:42 AM
Car: 1992 Camaro RS
This is actually great news for you!
10-bolt parts are MUCH cheaper and MUCH more common.
83 Crossfire TA
Jan 3, 2016 01:26 PM
TheTraut88
Sep 11, 2015 05:16 AM
middian
Sep 5, 2015 01:42 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
