Swapping an 8.8 I just got
Old Jun 25, 2014 | 10:59 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
So, I scored a complete 8.8-inch axle assembly from an '01 Mustang GT convertible, for $ 118 out the gate.
Now it's completely apart, and all the suspension brackets are off, but looking inside, I can't see what all the fuss is about. It doesn't seem impressive at all.
I know these things can be made to work, and I believe it starts out at least as strong as a max-effort 7.625, so I'm going to show what I do to get it under my third gen.
Anyone want to trade their 2.73s for my 3.27s?
Old Jun 25, 2014 | 11:14 AM
big gear head's Avatar
Re: Swapping an 8.8 I just got
The 8.8 Ford is built very much like the Chevy 12 bolt. The big difference between them is the axle size. Your '01 rear end is going to have 28 spline axles, which are the same size as the '90 and up 7.5 axles. Other than that everything else is much stronger. In '05 they finally upgraded the Mustang 8.8 to 31 spline axles.
Old Jun 25, 2014 | 05:01 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
You can get an OBX LSD for that rear new for $275 needs deburr and a preload spacer kit but it will be very strong and lots cheaper than a Truetrac....
Old Jun 25, 2014 | 05:48 PM
Mustang GT 8.8 already has a Trac Lock in it.
Old Jun 30, 2014 | 08:48 AM
cosmick's Avatar
The need for the torque arm is, to me, the best argument for the Mustang versions. The cast-on provisions for that dogbone damper can add strength to the bracket if fabricated accordingly. At least that's how it seems to me. Have a look at this pic to see what I kept, not only what I cut.
Old Jun 30, 2014 | 08:57 AM
cosmick's Avatar
Old Jun 30, 2014 | 08:58 AM
cosmick's Avatar
Old Jul 14, 2014 | 08:53 AM
cosmick's Avatar
Not having much luck finding weld-on housing ends specifically for this, except Mark Williams. Seems they're the only game in town.
Old Jul 14, 2014 | 08:58 AM
Moser Engineering has many weld on housing ends. They are some of the best because they allow you to use a OEM axle seal. What exactly do you need?
Old Jul 21, 2014 | 06:45 AM
cosmick's Avatar
I looked at Moser's, have you compared them against the M/W? M/W offers a jig, but to my untrained eye it looks like the Moser design actually requires the jig to weld them square. I'm not looking for lowest cost, I'm looking for newb-friendly, as none of the possible shops around me have ever welded housing ends before. My local Six States appears to have a setup for welding driveshafts while it turns the shaft, it looks like it might be able to turn the 8.8 without the pinion cone hitting the machine's base.
Old Jul 21, 2014 | 06:58 AM
You must have a housing fixture to weld the ends on. If you don't use the fixture you will probably ruin the splines on the axles or the axle bearings. Mittler Brothers has a very good housing fixture. It's the one that I have. http://www.mittlerbros.com/mittler-b...wing-kits.html
The Moser housing ends allow you to use the OEM axle seals. Strange ends do not. I don't know about Mark Williams ends. Doesn't matter who's ends you use, you still must use the fixture.
Old Jul 22, 2014 | 01:45 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
True but the OBX is a Helical LSD which is far superior. Basically like the Torsen in the 98 up ls1 cars only bigger and stronger. Or a Truetrac which is more expensive.
Old Jul 22, 2014 | 06:53 AM
cosmick's Avatar
So there's another reason to go M/W, their jig, or fixture as you call it, must be a more excellent match to their housing ends than mix-n-match. I just hope I don't end up near the cost of a Kwik Perf 9-inch with a junkyard chunk.
Old Jul 22, 2014 | 06:56 AM
cosmick's Avatar
But all far more costly than putting a rebuild kit in a 31 spline Traction-Lock. Doesn't matter that mine came with one, because it's only a 28 spline.
Old Jul 26, 2014 | 04:35 PM
cosmick's Avatar
http://www.mustangandfords.com/how-t...inch-rear-end/
Old Aug 7, 2014 | 09:03 AM
cosmick's Avatar
While I'm not progressing on that, I've been looking at other 8.8 swaps for their torque arm solutions, and I got some cardboard to mock up some ideas. Today I'm picking up some 1/2" mild steel. I'm wanting a 3-piece slip-fit, well, 3 pieces after welding, not counting bolts and nuts, captured by the rear cover bolts and encircling the pinion snout. Overdo it and forget it. I hope.
Old Aug 27, 2014 | 09:43 AM
cosmick's Avatar
Old Aug 27, 2014 | 09:44 AM
cosmick's Avatar
Old Aug 27, 2014 | 09:45 AM
cosmick's Avatar
Old Aug 27, 2014 | 09:46 AM
cosmick's Avatar
Old Aug 28, 2014 | 06:22 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Cool!
Is that a jeep comanche pickup?
Old Aug 28, 2014 | 07:46 AM
Looks like a S10 to me.
Old Aug 29, 2014 | 08:02 AM
cosmick's Avatar
S-10.
This torque arm bracket is looking to end up as several pieces of 1/4-inch mild steel welded together, getting the first piece figured out was great, even though it took me 3 attempts. The second piece is proving easier.
Old Aug 29, 2014 | 09:24 AM
Do you plan to weld this to the housing or are you making it bolt on?
Old Aug 30, 2014 | 09:50 AM
cosmick's Avatar
Originally Posted by stealtht/a
Cool!
Thanks.
Old Aug 30, 2014 | 09:58 AM
cosmick's Avatar
Probably bolt-on, as I'm uncertain about heat distortion. I don't want to be hurting pinion bearings, certainly. Plus then it could be transferred to another housing if necessary.
I'm sort of copying another old thread I found here. I forgot to note who gets the credit. But that wasn't a Mustang housing, and there were no plans to copy, so I have to figure out my own. Plus I do not agree with the way that person ground away the casting where I plan to separate the tube that holds the rear bolt. That should also help locate the bracket on the housing, if I make no mistake with drilling.
Why did you ask? Do you have a suggestion or some advice that might help? If so, please share.
Old Aug 30, 2014 | 11:12 AM
I was only going to let you know that if you weld it you need to use nickel rod to join the steel to the cast iron. I would recommend bolting it on like your plan. There seems to be plenty of material there to bolt it to.
Old Aug 30, 2014 | 11:18 AM
cosmick's Avatar
Thank you.
Old Sep 6, 2014 | 09:15 AM
cosmick's Avatar
Injured my right shoulder and upper arm, so no progress.
Old Sep 7, 2014 | 08:20 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Sorry to hear that after a solid thread start.
Old Sep 25, 2014 | 09:21 AM
cosmick's Avatar
Old Dec 10, 2014 | 10:16 AM
cosmick's Avatar
Why bother with a torque arm at all? I'm in the middle of doing another car for someone else, and have discovered the three-link suspension. Much like the '05-up 'stangs, the third link goes atop the diff, offset to the right side to counter the driveshaft torque.
Doing it to this other car is proving easy so far, once I drive it I may try the same on my '86 Camaro. First with my weak old 7.625" axle, and if that goes well, then with my 8.8"
Old Dec 14, 2014 | 03:37 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
True, but it is worth the extra money, and you won't have to rebuild it over and over again.
Old Dec 17, 2014 | 12:14 PM
cosmick's Avatar
Here's me doing the third link to a 200-horse '83 RX-7 with the 7.625" axle from a '94 S-10 Blazer 4x4:
And here's someone else's progress in a '79-'95 RX-7:
Old Dec 17, 2014 | 12:27 PM
cosmick's Avatar
But mine will have multiple holes for adjustability. The best tech about it is buried in this write-up by a real pro: http://www.lateral-g.net/forums/showthread.php4?t=42568
Old Feb 3, 2015 | 10:33 PM
54inches's Avatar
Car: CTSV
Engine: LS6
Damn I like that!
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
