Stripped transmission mount bolts
Car: 1992 Chevy Camaro RS
Engine: 305 TBI 5.0L
I was attempting to removed a broken transmission mount from my 92 RS. To my chagrin, i discovered that the two transmission bolts holding the mount in are stripped. Any suggestions on how to removed them? Thanks guys!
Re: Stripped transmission mount bolts
By stripped I mean that the bolt head is rounded off. A socket or wrench won't grab it. I was hoping to not cut it off...
Oh, that...
I'd suggest one of those socket-like things that has all the little pin/wire things in it, such that it conforms to any random shape whatsoever; and then new bolts.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
This with the PB Blaster or similar penetrating oil:
http://www.homedepot.com/p/Gator-Gri...120A/100351756
Or a Craftsman Bolt Out:
http://www.craftsman.com/search=Craf...0Remover%20Set
anyone ever try out a bolt extractor kit like these?
http://www.harborfreight.com/38-in-d...-pc-67894.html
http://www.griptitetools.com/Product...-Metric-43.htm
Car: '87 IROC
Engine: LB9
My only experience is with the Craftsman Bolt Out to remove a socket head cap screw (SHCS) that fastened an SLP runner to the lower intake manifold.
The SLP supplied ball end driver (IIRC, it was a Cal-Van tool) couldn't withstand the installation torque and the ball wedged and snapped off in the bolt socket. I just left it that way as the bolt was already tight.
Fast forward +10 years later when I needed to remove that bolt.
Car: `86 SS / `87 SS
My experience with the bolt-out was a knock sensor. Thankfully in a head and easy to reach, rather than just above the pan rail.
evilstuie
Jan 9, 2020 08:29 PM
ambainb
Apr 25, 2016 09:21 PM
