700r4 breather leak
Car: 1986Camaro Iroc z
Axle/Gears: 373 limited slip
700r4 breather leak
what can cause that the breather on top of a 700r4 blowing out oil?
the transmission was recently repaired
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: 700r4 breather leak
Overfilled or overheating come to mind quickly, but I think there are other possibilities as well, but can't remember then off the top of my head.
Car: 86 Trans Am WS6
Engine: 383 stroker
Start with checking the fluid level with the motor running, I had a shop over fill my transmission before as well as not set the detent cable correctly, they blew the front seal on its test drive so I took it home and swapped a rebuilt 700r4 in myself, never can trust a shop again after that.
This transmission can be overfull by a quart and a half and not have leaks at the breather (balance) tube. I suspect they used the early pump gasket, this can cause the leak. The early pump gasket still comes with all the paper & rubber (gasket) kits. They have not needed this gasket since the late gasket was introduced many years ago. The early front pump gasket was for the first year or two and the late gasket will retrofit. I throw out all of the early gaskets to make sure that what happened to you, never happens. Make sure that the leak is from there, and the fluid level is correct, and the transmission is not overfull. This might fix it.
Sorry for the late answer
and thanks that was the problem the gaskest on the pump, the wrong one,
again
the problem was fixed. Transmission running good and no leaks.
tyeo098
Nov 30, 2015 06:27 PM
bubbaz28
Sep 18, 2015 02:09 PM
