gear lube for a posi differential
Old Aug 23, 2014 | 04:03 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I am looking at putting a posi differential in my RS... Is it alright to use 85 140 plus posi additive when the differential calls for 80 90? Any input would be appreciated.
Old Aug 23, 2014 | 04:09 PM
Re: gear lube for a posi differential
85-140 = wheel bearing grease, compared to 75W-90 or 80W-90 which is more like thick oil
No it is not alright.
Use the right stuff. It's cheeeeeeeeep eeeeeeeeeezzy and plentiful. Follow the recommendations of the mfr of the posi you end up with. Don't go out of your way and do extra work just to do damage.
Old Aug 23, 2014 | 08:51 PM
big gear head's Avatar
Why would you want to use the thicker oil? There is no need to do that. It will run cooler with the correct oil.
You didn't say which differential you have. That makes a difference in what additive you need and how much. So what do you have?
Old Aug 24, 2014 | 09:11 AM
Well, I believe It's a 10 bolt posi, and it's in an 87 Camaro. The differential works fine and both tires will spin, but I can hear the ring and pinion gear whine a little, so I thought about using heavy duty 80 140 to quiet it down till I can have them replaced.
Old Aug 24, 2014 | 09:17 AM
If it's the original differential then it's probably an Auburn, but it could be a Governor Lock. The Auburn needs the oil additive, but the Gov Lock doesn't. If it's making noise then check the pinion nut to see if it's still tight. If the nut is tight then you probably have a bad bearing, or the gears are worn out.
Old Aug 24, 2014 | 08:48 PM
Well, to my knowledge 80 140 is a thick differential gear oil, and not grease.
Old Aug 24, 2014 | 08:58 PM
Relatively speaking, it is.
About like if your engine oil called for 0W-20, and instead you put 20W-50 in it.
It's the wrong thing for your car. Stick with the right stuff. Nothing to be gained by taking the extra risk, but everything to lose. Not a hard decision for a logical person.
Old Aug 25, 2014 | 04:19 PM
Sofakingdom, I believe in what you are saying. It's what I don't understand is what's the issue is at hand, and that is; would it harm the differential in any way if I used the heavy duty lube?
Old Aug 25, 2014 | 05:08 PM
Not in warm weather. When it gets cold it will take longer for the oil to start flowing and then it might cause a problem.
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
BOOT77
Sep 5, 2015 03:55 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
