What th400 crossmember will work with mufflex y-pipe?
Old Dec 29, 2014 | 03:32 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I've searched here and and Google without a real clear answer. I know the spohn won't because I tried it 10 years ago. I fabbed up my own torque arm mount onto the factory crossmember. I may have to fab up something again but thought I'd ask here.
I did call bmr and umi. Bmr wants me to send pics of the y-pipe on the car and umi says their crossmember hangs too low.
Old Dec 29, 2014 | 06:40 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: What th400 crossmember will work with mufflex y-pipe?
The old Hurst 500-0002 clears most Y pipes, but it's not a torque arm mount crossmember. It has the plate that bolts to tailshaft of trans.
Old Dec 29, 2014 | 06:46 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Where could I see a pic of this?
Old Dec 29, 2014 | 08:13 PM
Car: 1988 Camaro
No Y pipe on my car (dual exhaust) but here is the hurst crossmember. A buddy of mine had the same one and ran a Y pipe with his. I can't remember what Y pipe but it was about 8 years ago and he bought it from summit.
Attached Thumbnails What th400 crossmember will work with mufflex y-pipe?-picture-162.jpg   What th400 crossmember will work with mufflex y-pipe?-picture-167.jpg   What th400 crossmember will work with mufflex y-pipe?-picture-165.jpg
Old Dec 29, 2014 | 09:49 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Thanks for the pictures. That helps for sure. It appears that I'd need a factory piece to use parts off of.
Old Dec 30, 2014 | 12:48 AM
Car: 1988 Camaro
Your welcome.. Yeah the old Hurst kit used the top half of the 2 pc. with rubber biscuit stock crossmember and you have to trim the lip sticking down off it.
Really you could just use a pc. of flat bar or plate steel to go across the hurst crossmember. When I 1st built my car over 10 years ago I just happen to have one of those factory 2 pc crossmembers and used that. I now have a pc. 1/8" thick plate in place of that factory part as the factory part flexed in the center too much.
Old Dec 30, 2014 | 12:54 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I can't find any place that sells the hurst crossmember. I did find a torque arm relocation bracket mad by hurst.
Old Dec 30, 2014 | 01:17 AM
Car: 1988 Camaro
Hmmm, I'll look and see what I can find. Like I said it's an old part. I bought mine new from Summit back in 2004. It was sold as a kit. Came with crossmember, torque arm bracket that mounts to tail of th-400, some vac line, vac fittings, shift cable brackets, shift lever/arm, nuts, bolts, etc
It was listed as Hurst #500-0002 turbo 400 swap kit - 1982-89 camaro/firebird
The copyright date on the paperwork with mine said 1989 lol.
It was the main th-400 swap kit back in the day, and the B&M kit was the main th-350 swap kit.
Old Dec 30, 2014 | 01:55 AM
Car: 1988 Camaro
Hmmm, I don't think they make it any longer with the crossmember. They have #5500001 which use to be the th-350 hurst swap kit. It's the TQ arm bracket, vac lines and what not, no crossmember.
Summit still shows the 5500002 but says "Not Available"
http://www.summitracing.com/parts/huu-5500002
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Elliswon
Aug 10, 2015 12:33 PM
