Would this ring and pinion fit?
Old 03-17-2015, 05:50 PM
MustangBeater20's Avatar
Car: 1991 Camaro RS
Engine: Built TBI 350
Axle/Gears: 3.42 Posi
I have a 91 Camaro RS and the rear end is stock. I was going to keep the 3.08 gears and bought a 4th Gen Camaro carrier. However, I changed my mind and now want 3.42. I was wondering if this ring and pinion would fit the carrier and the rear end. By the way, the car has a 28 splines.
http://m.summitracing.com/parts/sum-741014/overview/
Old 03-17-2015, 06:29 PM
big gear head's Avatar
Re: Would this ring and pinion fit?
What gears were on the 4th gen differential? If it's a 2 series then it will work. If it's a 3 series then it won't work.
Old 03-17-2015, 07:03 PM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
4th gen carriers are (like third gens) 2-series if 2.73 or 3.08.
And they're 3-series if 3.23 or 3.42.
Summit shows " Carrier Series: 2 " on those 3.42 gears. So, the gears you linked are a 3-series ratio but thicker to work with a 2-series carrier. So they will work with a carrier from a 2.73 4th gen, for example.
Old post with a good pic of 2 vs 3 series: https://www.thirdgen.org/forums/tran...i-carrier.html
Your stock 28 spline axles will work with a 4th gen carrier.
Old 03-17-2015, 08:05 PM
Car: 1991 Camaro RS
Why does it say 27 spline count instead of 28?
Old 03-17-2015, 08:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
27 is the pinion gear spline count
Old 03-17-2015, 09:05 PM
Correct, 27 splines on the pinion shaft, not the axles.
Old 03-17-2015, 09:32 PM
Car: 1991 Camaro RS
Would you go with the thicker gears? Or with a spacer?
Old 03-18-2015, 07:20 AM
DO NOT use a spacer. They create HUGE problems. If you have a 2 series differential then use the thick gear, or get a 3 series for the standard gear.
Old 03-18-2015, 08:27 AM
Car: 1991 Camaro RS
That's what I thought! Thanks for all the advice!
hectre13
12-11-2023 08:14 AM
lt1z350
09-29-2015 01:50 PM
New2Chevy
09-28-2015 12:35 AM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
hectre13
08-26-2015 08:17 AM
Quick Reply: Would this ring and pinion fit?
