Process for bleeding stock GM T-56 Clutch slave?
Old May 5, 2015 | 01:22 PM
michael's Avatar
Car: 1991 Formula
Engine: 6.2 383 TPIS Miniram
Axle/Gears: Moser 9" 4.11
I get unbolting the slave from the housing and holding it at a 45* angle. Does the reservoir cap need to be off or leave it on?
Old May 5, 2015 | 05:47 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Process for bleeding stock GM T-56 Clutch slave?
Leave on, less mess.
Old May 6, 2015 | 09:08 AM
michael's Avatar
Car: 1991 Formula
I'm also seeing stuff about using zip ties on the clutch pedal to hold it up or pulling the MC pin to the pedal clip so there is no resistance in the system when bleeding the slave anyone doing that?
Just guessing but I assume that I can't just do this the easy way and ramp the front end. I assume I need to drag out the jack and stands to make the car level for this?
Old May 10, 2015 | 03:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Never heard of that and have never needed to do it.
backtothe80s
Sep 5, 2015 12:39 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
cRoe4
Aug 7, 2015 08:46 PM
rsrmoore
Aug 7, 2015 08:44 PM
