4th gen posi in late 3rd gen (28 spline)?
Old Jun 15, 2015 | 02:45 PM
Jonny45's Avatar
Car: 1988 Firebird
Engine: Built 3.4 swap
Transmission: worldclass T5
Axle/Gears: 3.23 28 spine posi with moser axles
I just picked up a 28 spline axle setup out of a 90 camaro for 100 bucks....but its open
Can i run a posi unit out of a 4th gen? If so what years should i look for...the axle has 3.23 gears now.
Thanks in advance!
Old Jun 15, 2015 | 02:58 PM
Jonny45's Avatar
Car: 1988 Firebird
Re: 4th gen posi in late 3rd gen (28 spline)?
Never mind i found a sticky on this 93-97 will work
Gotta stop viewing this on a little phone screen.....
Delete if wanted
Old Jun 15, 2015 | 03:00 PM
big gear head's Avatar
Old Jun 15, 2015 | 03:48 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
What you really want is a 99-02 Torsen posi out of a Trans Am or SS Camaro, they don't have any clutches to wear out. I have one in my car & I love it.
Old Jun 15, 2015 | 04:39 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Same. Very nice unit. Bolts right into the 3rd gen rear.
Old Jun 15, 2015 | 06:27 PM
And it doesn't require any special additives, which is a plus
Old Jun 15, 2015 | 06:51 PM
Well it doesn't exactly bolt in. There is shimming to be done.
Old Jun 15, 2015 | 07:15 PM
ONE EYE's Avatar
Car: 88GMC 4x4, 1999 SS 99u camaro, '82 Z28
Engine: L69, LS1, ZZ4,
Transmission: 700r4, T-56, T-5
when I got my 99 it had the torsen, argued with gm cause was misinformed by dealer about options, so in the end I got the optional auburn posi and special rear end cover option. I will tell you this, the difference you feel everything being the same, it went from torsen (felt like walking on icy road) to auburn (felt like cat clawing on carpet to get away from a dog) I can see how people don't want the maintenance of auburn, but I would choose it over any, the clutch rebuilding in future, and special additive is so worth it compared to torsen. I no matter what use gm posi lube, seems better than the rest.
Old Jun 15, 2015 | 07:20 PM
It's good that the Auburn worked well for you, but it's actually one of, if not the worst differential available. I wouldn't put one in my car if it was free and someone paid me to put it in. I've had too many bad experiences with the Auburn in customer's cars and I will not install one anymore, even if that's what the customer wants. The last customer that came in and wanted an Auburn ended up with an Eaton Posi. That was not their choice, but mine. I am tired of them coming back for warranty work and complete rear end rebuilds, so no more Auburns from my shop.
Old Jun 15, 2015 | 08:44 PM
I'm pretty surprised to hear that, as I did a lot of research before I bought mine & I've honestly never read a complaint about a torsen LSD. I've had mine in a year & the only time my car has been lacking traction was in reverse, because the torsen is a one way LSD, lol.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
mcgarnicle
Aug 12, 2015 04:58 PM
