th350 swap no vss signal to ecm
Old Jul 12, 2015 | 07:57 PM
timonator's Avatar
My 87 GTA has a 350 trans that someone swapped in. I keep getting a code 24 and have no speedometer. What I read about this code is that the ecm is not getting any signal from the vss which affects the IAC and ignition timing. I usually have to hold the gas pedal to the floor and it runs really rich "rollin coal" is what my son called it the other day. What can I do to get the vss signal to the ecm ? I don't want to spend any money on it since I am going to do an LS1/4L60E swap soon.
Old Jul 12, 2015 | 08:34 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: th350 swap no vss signal to ecm
Depends on what tailhousng and parts are on it.
If it has a 700-R4 tailhousing and 700-R4 speedometer gears, use the 87 VSS and connect to the wiring like stock. Might have an incorrect one.
If it has different speedometer gears, get an aftermarket VSS that threads onto the speedo gear sleeve.
Old Jul 12, 2015 | 08:44 PM
timonator's Avatar
It looks like a 700r4 tailshaft and vss. I don't know about the gear inside.
Old Jul 12, 2015 | 08:52 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
what do you mean when you say you "have no speedometer"?
that there physically isn't one in the car, or that it doesn't register speed?
does an 87 GTA have a mechanically driven speedo like a Camaro? if so, then the VSS is built into the speedo head and you probably need a cable..
Old Jul 12, 2015 | 08:57 PM
timonator's Avatar
The speedometer needle doesn't move. The tailshaft has a speed sensor with 2 wires. No cable whereas my sons 86 iroc has a speedmeter cable.
Old Jul 13, 2015 | 12:43 PM
timonator's Avatar
Any ideas ?
Old Jul 13, 2015 | 06:56 PM
jmd's Avatar
jmd
Pop the VSS out and verify there are gears in there.
It'll be speedometer gears, but they drive the VSS. All third gens had this.
If it has them, you pretty much need to follow factory service manual technique to troubleshoot the wiring & VSS to determine location of fault.
Old Jul 13, 2015 | 08:54 PM
timonator's Avatar
Yep, there's gears in there. But they don't mesh. The gear on the output shaft is too far forward.
Old Jul 13, 2015 | 10:53 PM
jmd's Avatar
jmd
I don't know the TH350 output shaft speedo gear locations off the top of my head.
If the rear is on jackstands, put it in neutral.
With the VSS popped out, spin things and look to see if there is another hole rearward on the output shaft. If there is, remove the torque arm from the bracket, pull the driveshaft, then the tailhousing. Depress the gear clip, slide things back and put the gear where it needs to be.
If there's no additional hole, but there's a correct place for the gear to sit, use a diamond sphere dremel bit set. Start w/ the tiny round one and add a hole for the clip where it's supposed to be to retain the gear.
And just think of how much faster this would have gone if you had checked those speedo gears and posted about them in post 1!
89GTAOz
May 16, 2020 09:31 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
mizz0313
Aug 12, 2015 06:45 AM
djmarch
Aug 10, 2015 08:42 AM
Fronzizzle
Aug 9, 2015 01:15 PM
