9 bolt LSD change
Old Jul 16, 2015 | 09:26 AM
Dou99er's Avatar
Car: 89 Iroc
Engine: 5.7 350
9 bolt LSD change
I just picked up a 1989 GTA it has a 9 bolt with 3.27 gears and a LSD. Upon inspection of the differential with pressure on one wheel I can rotate the wheel that has no pressure with ease. It also has the axle seals and housing where leaking bad.
So i picked up another 9 bolt off craigslist that the lSD locks up and can barley move the one end with pressure on the opposite axle. The axle i picked up is 2.77 gear.
My question is should I install new bearings or do you think I can get away with the bearings that are on the craigslist one. I am already going to axle bearings and seals is there anything else I should consider when doing this change.
Old Jul 16, 2015 | 12:28 PM
big gear head's Avatar
Re: 9 bolt LSD change
It's not going to work. The 2.77 gear fits a 2 series differential and the 3.27 gear fits a 3 series differential. You can't install the 3.27 gear on the differential that came out of the 2.77 rear end.
Old Jul 16, 2015 | 12:31 PM
Dou99er's Avatar
Car: 89 Iroc
Engine: 5.7 350
No good. Well back to square one do you think if the gear oil had been changed without friction modifier that once I add some that it will work better
Old Jul 16, 2015 | 02:40 PM
There are several threads on here about reconditioning the LSD in the 9 bolt. Check them out. Changing the oil probably won't help.
Old Jul 16, 2015 | 03:40 PM
Dou99er's Avatar
Car: 89 Iroc
Engine: 5.7 350
That's the road I am going down now. Can I use the Cones and spider gears from the 2.77 rear?
Old Jul 16, 2015 | 04:33 PM
Yes, if they are better than what came out of the 3.27 rear end.
Old Jul 16, 2015 | 06:48 PM
Dou99er's Avatar
Car: 89 Iroc
Engine: 5.7 350
Old Jul 16, 2015 | 06:49 PM
Dou99er's Avatar
Car: 89 Iroc
Engine: 5.7 350
Thanks for all the help will see if I can get this done this weekend. Here is a pic of 3.27 cone completely bottomed out. I don't know if anything is messed up yet but my guess would it's probably not good.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Dwayne614
Sep 28, 2015 08:33 AM
355tpipickup
Aug 19, 2015 10:02 PM
johanlindgren
Aug 16, 2015 12:16 AM
