T56 swap
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
T56 swap
Im putting the t56 in my iroc soon and was wondering if anyone would know where to get a flywheel for a 2 piece rear main, summit has one but its 500+ or could i use my t5 flywheel with the 4th gen clutch? Please help!
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: T56 swap
Before you start, do a bunch of research you will find the flywheel is not your only problem.
But no, you can't use a T-5 model
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
I know what it consists of, thats the only snag i have is the flywheel. I have everything else to do it just cant find a flywheel for a 2 piece rear main that can be used with a 4th gen clutch
Received 1,681 Likes
Re: T56 swap
There is no such thing, except a specifically designed aftermarket "swap" piece.
With an aftermarket bell housing and some other clutch actuation system, your choices are considerably expanded; but that's usually more $$$ than the swapper flywheel.
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: T56 swap
copied from this thread https://www.thirdgen.org/forums/tran...-flywheel.html .. found using a search
Flywheel's with neutral balance for 2 piece rms pre-86 sbc + lt1 T56... 'that i have found so far'
Fidanza - 198661 13.5 lbs.
Ram Clutches - 2555 18 lbs.
Spec Clutches - SC66A 13.2 lbs.
Spec Clutches - SC66S 25.9 lbs. steel
Centerforce - 700107 35.5 lbs. steel
McLeod - 460370 25 lbs. steel
American PowerTrain - FWCV-11006 32 lbs. steel
1 Post
Car: 85 iroc with 92 ground effects
Engine: 355 11.1 world product heads
Transmission: t56
Axle/Gears: 3.54 dana 44
Re: T56 swap
I used the fidanza aluminum flywheel. It was for a neutral balanced 2 piece rear main. It works perfect in my car and worked with a 4th gen clutch. I did buy longer arp pressure plate bolts so they grabbed more into the aluminum flywheel.
I paid 350 new for mine on sale.
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
Thank you for the list! American power train has one for $450 i would prefer the fidanza though would you know if it would use an 11 inch clutch? Centerforce and american power train are the only ones that specify that they use the 11 inch clutch and they are over 30 pounds
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
I mean the flywheel, im having trouble finding one for a 2 piece rear main that uses an 11 inch clutch all that i am finding use 10.4-10.5 inch
Re: T56 swap
AFAIK all the aftermarket flywheels use the stock size LT1 clutch, whatever that is. Doesn't too much matter once you reach that point... either you can bolt it up, or you can't.
Re: T56 swap
There are several part numbers posted. The only trouble in finding one is there are so many tempting cheaper examples of flywheels that are not what you need.
If you found a flywheel indicating it's 153 tooth Chevrolet 2pc RMS for 10.5" clutch, then you found a T5 flywheel.
You need a conversion 93-97 T56 flywheel for 2pc RMS. Several part numbers have been posted. If it's for 93-97 T56, the clutch size is 11".
Post links and we can confirm. Or, be daring and call the mfgr.
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
I found 2 of them one is centerforce made for the conversion its $584 and its steel at 30 lb. American power train has the same thing, steel at $450. I would like an aluminum one but it does not seem to exist
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
I did, i called fidanza they said all they have available is the 10.5" but its listing says to bolt f body 6 speed to 2 piece rear main engine i called because it doesnt say what clutch size and they told me its not what im looking for its not for 11" clutch
1 Post
Transmission: t56
Re: T56 swap
here is the clutch
http://www.ebay.com/itm/XTD-STAGE-3-DUAL-FRICTION-CLUTCH-KIT-CAMARO-Z28-PONTIAC-FORMULA-TRANS-AM-5-7L-/191651058819?hash=item2c9f4b1483
pressure plate bolts... stock lt1 only grab the flywheel by a few threads which isn't good in aluminum.. I bought and used these. I had to cut off around a 1/4 so they wouldn't bottom out in the flywheel. Sucks you have to buy 2 packs to get 6 bolts. I also weighed each one after cutting them to make them way exactly the same weight
http://www.ebay.com/itm/ARP-652-1750-3-8-16-Chromemoly-Bolts-/400706923863?hash=item5d4bfe6d57
Also run arp flywheel bolts... The ones fidanza supplied weren't the greatest
http://www.ebay.com/itm/ARP-100-2801-Flywheel-Bolts-Kit-Chromoly-Steel-Chevy-Ford-7-16-20-/191545895399?hash=item2c990669e7
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
Re: T56 swap
Do you have a part number for that flywheel? And what do you think of a 6 puck disk, i was looking at a stage 3 6puck clutch kit by the same brand on ebay
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
Re: T56 swap
i found a flywheel finialy, spec makes it i called them they varified that its for the swap 2 piece rear main lt1 pull style 11" clutch best of all its aluminum its 13.5 pounds part number is sc66a and $465 i am definately buying those arp bolts to go with it
1 Post
Transmission: t56
Re: T56 swap
http://www.lmperformance.com/663697
Is where I bought my fidanza from... Showed up in less then a week.
Fidanza 198661 is what I used. Which worked with everything for the lt1 clutch
As for a 6 puck I couldn't really tell you. I never used one. I would be worried about chatter. My dual friction clutch chattered some for the first 500 miles or so. It has gotten better
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
Re: T56 swap
Ok cool, that will save me 100 bucks, i have a stage 3 6puck in my car now with my t5 its not bad, i may go with the dule friction when i put the t56, im not sure yet
1 Post
Transmission: t56
Re: T56 swap
Glad to help out. I did hours and hours of research. Also you can keep the 3rd gen pedals and master if you use like a 1988 cavalier slave. It is larger in diameter at 1.25 and keep from over extending the pressure plate.
Also what crossmember you going to use. I had to make up my own because of long tubes with 3 inch y and I wanted torque arm off the trans.
How I made mine... Maybe will give you ideas
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
Re: T56 swap
Hawks third gen has basicly the same thing made for long tubes for $120 on ebay, i may make my own, i like that design and it looks great i have shortys on mine now and i made my whole exhaust system free flowing no restrictions it sounds good too, got 2.5" from the headers back in to 18" long 3.5" angle cut tips so you see no pipe comming out of the back just tips im pretty proud of it lol next time im under my car ill put some pics up
1 Post
Transmission: t56
Re: T56 swap
Very nice, I don't like seeing exhaust tips on camaros with the ground effects. Mine are tucked where you can not see them either. My setup is 3 inch homemade y pipe back to an adjustable borla 4th gen setup muffler set up i picked up for 50 bucks. Where the plate goes for the other tail pipe I have a qtp cutout so basically straight 3inch pipe when its open.
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
Re: T56 swap
Personal prefrences lol mines all straight pipe i made my own y pipe also, no muffler, i got a 1992 crate 350 with a mild cam in it im not sure what it is but it has a nice lump to it, i think it sounds pretty good. I got a 383 stroker im puttin in either over the winter or in early spring, plan on having the t56 in soon er then that though lol thank you for all the info
1992 Trans Am
08-08-2015 08:16 PM
