Signaling N neutral
Old Dec 9, 2015 | 05:27 PM
NiG's Avatar
NiG
Car: 1989 Gray ttop GTA
Engine: 5700cc
Transmission: auto 700R4
Signaling N neutral
Hi all
Is there a simple way to detect you put the gear in N mode?
That's, for example, if I want to light a LED or a buzzer, when I put N to avoid me to accidentally put the R while the car is moving forward.
THANKS
Old Dec 10, 2015 | 05:35 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Signaling N neutral
Could tie onto the neutral saftey wiring at the shifter or pedals.
or just don't put the shifter into reverse when your moving, I don't see why this problem would cone up? You have to press the button on the shifter to get into reverse from drive or neutral anyway.
Old Dec 10, 2015 | 07:49 AM
NiG's Avatar
NiG
Engine: 5700cc
I have this particular, which I consider nice, way of driving: when I know I'll have to stop soon (which is frequent in Italy streets), instead of running and then brake just before, I put in N and let the car go forward by inertia.
This allow me to:
- save gas
- save brakes (because I have to start stop from a lower speed)
- save transmission, because I avoid it to shift from 4 to 3 to 2 to 1.
In any case, I consider a usefull advice knowing when you are in N.
What is the neutral saftey wiring?
thanks!
Old Dec 10, 2015 | 01:53 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
You know your car is in neutral when the shifter is in the neutral position...
Neutral safety switch doesn't have any kind of signal wire for neutral, it simply energizes the starter wires when it detects the gear selector is either in PARK or NEUTRAL. To get any kind of neutral only light, you'd probably have to figure out how to install some sort of micro-switch on the shifter mechanism.
Old Dec 12, 2015 | 09:40 AM
NiG's Avatar
NiG
Engine: 5700cc
yeah I tghought the same thing, which is not simple at all :/
thanks anyway
Old Jan 8, 2016 | 08:08 PM
powder white's Avatar
Car: 82 Z28
Engine: 350 LT1
hey was up all i have a problem my car starts in all gears
the person i bought the car from rigged it and i want to fix it right
i need help on this matter
Old Jan 14, 2016 | 12:27 PM
Sounds like someone bypassed the neutral safety switch. Get some sort of shop manual, you'll need it if you bought someone else's old project car.
Old Jan 14, 2016 | 01:05 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
This allow me to:
- save gas
thanks!
Your method doesn't quite make sense.
- Your car will idle higher in N than in gear, so you'll burn more gas coasting/sitting in N than in gear.
- An automatic transmission doesn't cycle through each gear when slowing down, It'll stay in (over) drive until you stop, then it shifts into 1st.
- Also, as has been said before, with an automatic shifter you can throw it from R to D without hitting the button, but if you just slide from D to R it will stop you in N because in order to shift from N to R the button must be pressed.
hope that helps.
OldMan89
Sep 7, 2023 01:44 AM
ndndndnd
Dec 30, 2015 01:13 PM
SteelheadBen
Dec 15, 2015 04:11 PM
n.ward1990
Dec 9, 2015 11:49 PM
camaroz1979
Exterior Parts for Sale
Dec 7, 2015 04:31 PM
