T56 to a gen 1 sbc?
Old Feb 10, 2018 | 04:25 PM
Dwelch396's Avatar
T56 to a gen 1 sbc?
Hello all, new user here, I hope someone can help me or point me in the right direction with my swap, it's a long story but I'll try to sum it up,
I have a 1983 Chevy camaro z28, it has a gen 1 small block with a t5 manual in it, I'm swapping in a 1993 camaro z28 t56 manual. I bought the trans with the 1993 flywheel and clutch.
when we tried to install it the 1993 flywheel did not match the bolt holes on the gen 1 sbc, I was tolled that there are 2 types of flywheel for the different rear main seals, and the only flywheels I was able to locate where very expensive custom jobs.
has anyone had this problem? Anyone got any cheaper alternatives?
thanks!
Old Feb 10, 2018 | 04:28 PM
Drew's Avatar
Re: T56 to a gen 1 sbc?
https://www.thirdgen.org/forums/tran...ap-thread.html
Old Feb 10, 2018 | 05:34 PM
Also:
https://www.thirdgen.org/forums/faq-...questions.html
A brief search of this forum for "T-56" will turn up everything you could possibly want to know, and about 10 times as much stuff more that you don't even know you don't know yet. Be aware though, a bunch of it is obsolete; people that used to make or do stuff that you used to could buy, but not anymore.
Old Feb 12, 2018 | 02:18 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
iirc
Centerforce Steel flywheel 700107
Ram aluminium 2555
McLeod 64033-00-07
All adapt a 2piece RMS to t56
Old Feb 27, 2018 | 12:59 PM
Dwelch396's Avatar
Thanks all for the pointers, I was hopping for something cheaper since I'm going to be doing an engine swap in a few months,
what kind of flywheel would I need for a 350 vortec one pice rear main in order for the t56 to work with it? Is there anything special for it?
Old Feb 27, 2018 | 05:37 PM
The stock LT1 one will work fine.
Old Mar 1, 2018 | 04:52 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
https://www.thirdgen.org/forums/tran...28-t-56-a.html. See my post here.
high c
Nov 12, 2006 11:54 AM
JPrevost
Apr 19, 2005 03:32 PM
REVLIMIT
Nov 2, 2002 10:10 PM
